Thermodynamic filling of tank. (matlab)
The discussion revolves around modeling the pressurization process of a rigid insulated tank containing air, using MATLAB. Participants are exploring the equations and algorithms necessary to calculate the pressure, temperature, mass flow rate, and time required to fill the tank with air from a supply line.
  • Homework-related
  • One participant describes the initial conditions of the tank and the equations used in their MATLAB program to model the process.
  • Another participant questions the method used to calculate the time to fill the tank, suggesting a lack of clarity in the approach to finding the mass flow rate.
  • Concerns are raised about the absence of the discharge coefficient (Cd) in the mass flow rate equation, with a reference provided for further information.
  • A participant mentions an attempt to implement a critical pressure condition in their flow equation, noting that it resulted in an increase in the calculated time.
  • Another participant shares a similar problem involving refrigerant and seeks help, indicating a broader context of thermal dynamics challenges.
  • One participant references a NASA document that suggests a longer time to fill a tank than the 8 seconds claimed by the original poster.
  • The original poster defends their 8-second estimate, explaining adjustments made to their pressure units but acknowledges potential errors in their calculations.
  • Suggestions are made to perform hand calculations to verify the program's output against expected results for the first iterations.
Participants generally agree on the final temperature and mass values calculated by the original poster, but there is disagreement regarding the time required to pressurize the tank. Multiple competing views remain about the accuracy of the calculations and the methodology used.
Participants express uncertainty about the correctness of the equations used, particularly regarding the mass flow rate and the impact of critical pressure conditions. There are unresolved questions about the assumptions made in the calculations and the definitions of variables.
Juanka
A 70 ft3 rigid insulated tank contains air at 14.7 psia and 80 º F. The tank is connected to a supply line through a valve. Air is flowing in the supply line at 75 psia and 80 º F. The valve is opened, and air is allowed to enter the tank until the pressure in the tank reaches the line pressure, at which point the valve is closed. The diameter of the connecting pipe is 1 inch.
Write a computer program to model the pressurization process in the tank. The computer program will calculate the pressure, temperature, mass flowrate into the tank and resident mass during the process. Determine the final temperature, mass of air in the tank and time required to pressurize the tank.
All the relevant equations are labeled in the coding
Code:
P1=75; % in psi
T1=(80+459.67); %in R
A1=(pi*1)/(4*144); % Area in ft^2
D1=1; % Diameter in inch
P2=(14.7); % in psi
T2=T1; %in R
V2=70; % in ft^3
Cp=0.24; % in Btu/lb-R
Cv=0.17; % in Btu/lb-R
k=1.4;% gamma
Cd=0.6; % is unitless
R=53.33; % in ft-lb/lb/R
rho1=(P1*144)/(R*T1); % density in lb/ft^3
rho2=(P2*144)/(R*T2); % density in lb/ft^3
mass2=(rho2*V2); % mass in lb
g=32.174; % in ft/sec^2
dt=0.01; % change in time intervals
n=1;
m(1)=mass2;
P(1)=P2;
T(1)=T2;while P2<P1-.01
    error=1;
       n=n+1;
    while error>0.001
        %Equations
       mdot=A1*sqrt(((2*k)/(k-1))*P1*g*rho1*(P2/P1)^(2/k)*(1-(P2/P1))^(k-1/k));
        mass2new=mass2+mdot*dt;
        u=(mass2*Cv*T2+mdot*Cp*T1*dt)/mass2new; %energy equation
        T2=u/Cv;
        P2new=mass2new*R*T2/(V2*144);
        error=abs(P2new-P2)/P2;
        P2=P2new;
    end
    mass2=mass2new;
    T(n)=T2;
    P(n)=P2;
    m(n)=mass2new;
    t(n)=n*dt;
end%% Output
fprintf('The final temperature = %7.3f R\n',T2)
fprintf('The mass of air in tank = %7.3f lb\n',mass2new)
fprintf('The time required to pressurize the tank = %7.3f s\n',t(n))
figure(1)
plot(t,T,'g','Linewidth',2)
grid
ylabel('Temperature (R)')
xlabel('Time (s)')
title('Time Vs Temperature')
figure(2)
plot(t,P,'b','Linewidth',2)
grid
xlabel('Time (s)')
ylabel('Pressure (psi)')
title('Time Vs Pressure')
figure(3)
plot(t,m,'r','Linewidth',2)
grid
xlabel('Time (s)')
ylabel('Mass (lb)')
title('Time Vs Mass')
correct answer should be
Time around 8 seconds
Temperature around 700 Rankine
and I do not know what the mass should be.
my answers are:
The final temperature = 704.984 R
The mass of air in tank = 20.106 lb
The time required to pressurize the tank = 82.710 s
I do not know where the error in my coding is or if it is in one of my equations I have retyped them multiple times making sure the equations are correct and I am 99% correct that my algorithm is correct, any suggestions on where there error is coming from??
The final temperature and mass look right. I am not following your process for finding the time to fill the tank. It looks like you are trying to find the mass flow rate of a gas through a valve and then finding a new Mass2, U, T2 and P2 with a time step of .01 seconds but not sure.
where is Cd in your mass flow rate equation?
http://ntrs.nasa.gov/archive/nasa/casi.ntrs.nasa.gov/19970032263_1997030443.pdf"
The above line is more information on the problem however the reason I am sending it is because on page 3 is the flow equation.
To answer your other reply yes, I believe my final temperature and mass are correct I tried inserting an if loop directly under my flow equation
Code:
if (P2/P1) <= (2/(k+1))^(k/(k-1))
(P2/P1)= (2/(k+1))^(k/(k-1))
(2/(k+1))^(k/(k-1)) is the pressure critical.
However this only made my time increase.
Any idea what could be going on?
i have almost the same problem and i can't solve it ;( please anybody help me
A Rigid tank is filled with refrigerant R-134a at 300 K. An electric current of 0.1 Amps
over 120 Volts is passed through the refrigerant for 1 minute. The tank is not very well insulated.
After many hours, the temperature is measured to be 300 K again. How much heat (if any) the
refrigerant lost?
Figure 4, Case 3 of the NASA document shows 80 seconds to fill 2 CU.liters. Are you sure your 8 seconds is correct?
Yes I am sure 8 seconds is correct, however I realized in my flow equation I have P1 in psi not psf so I multiplied it by 144, but I did not change the values for p1 or p2 because (p1/p2) if both are in psf or psi is the same to better demonstrate what I did the code is below, however I am closer to the answer I must just have a simple error somewhere.
Code:
P1=75; % in psi
P2=(14.7); % in psi
T2=T1; %in R
V2=70; % in ft^3
k=1.4;% gamma
n=1;
m(1)=mass2;
P(1)=P2;
T(1)=T2;
Pcrit=(2/(k+1))^(k/(k-1));
Prat= (P2/P1);
while P2<P1-.01
    error=1;
       n=n+1;
    while error>0.001
        %Equations
       mdot=A1*sqrt(((2*k)/(k-1))*P1*144*g*rho1*Prat^(2/k)*(1-(Prat))^(k-1/k));
        if Prat <= Pcrit;
            Prat= Pcrit;
        end
        T2=u/Cv;
        P2=P2new;
    end
    mass2=mass2new;
    T(n)=T2;
    P(n)=P2;
    m(n)=mass2new;
    t(n)=n*dt;
end
%% Output
figure(1)
grid
xlabel('Time (s)')
figure(2)
grid
xlabel('Time (s)')
figure(3)
grid
xlabel('Time (s)')
ylabel('Mass (lb)')
Did you try a hand calculation on either side of 8 seconds and then have your program print the results for the same time period. You might be able to find the error that way.
I am currently hand calculating the first two iterations, just to see if the values I calculate match what the program is outputting for the first two iterations.
12K
