About small displacement method for phonons
The small displacement method for calculating phonons requires that the wave vector k be orthogonal to the supercell size, meaning not all k vectors are permissible. Each choice of k vector necessitates a full electronic calculation, and the supercell must accommodate the periodicity of the k vector. Additionally, a sufficiently large supercell is essential to minimize the Hellmann-Feynman force outside the supercell, as the dynamical matrix involves an infinite summation of force constants.
  • Understanding of phonon calculations in solid-state physics
  • Familiarity with the small displacement method
  • Knowledge of supercell construction in computational materials science
  • Experience with electronic structure calculations
  • Research the implementation of the small displacement method in Quantum ESPRESSO
  • Learn about the construction and optimization of supercells in VASP
  • Study the Hellmann-Feynman theorem and its implications in phonon calculations
  • Explore the use of k-point sampling in density functional theory (DFT) calculations
Researchers and practitioners in computational materials science, particularly those focused on phonon calculations and electronic structure methods.
Hyla Brook
Dear All,
I have trouble to understand the calculation of phonon using small displacement method. I found people said the limitation of this method was that it requires the wave vector k orthogonal to the supercell size(?). Does it mean the wave vector is not any you want? why? I got really confused. Any idea is highly appreciated. Thank you!
H.B
Yes. You have to do a full electronic calculation for each choice of the k vector of the displacement. The super-cell has to fit the period of the k-vector.
Thank you for reply Dr. Du. But in the program (e.g. phon), the number of k point is variable. That means we can choose any k wave vector we want in the BZ.
The tutorial of this program says the limitation of this method is we need a large supercell to make Hellmann-Feynman force negligible outside the supercell. I think this is easy to understand because the element of the dynamical matrix is a summation involving the force constants, which in principle has infinite terms. I asked that question because that explanation was mentioned as equivalent as this one. I cannot even understand that well.
Could you explain it more?
  • · Replies 0 ·
