I think my Prof did this wrong, Need
  • Context: Graduate
  • Thread starter Thread starter RagincajunLA
The discussion revolves around the calculation of relativistic force and the application of derivatives in the context of relativistic momentum. Participants are examining the correctness of a quiz question related to the expression for force in terms of relativistic momentum, acceleration, mass, and the Lorentz factor.
  • One participant asserts that the force can be expressed as F = γ_u * m * a, suggesting this is analogous to the classical F = ma equation but modified by the Lorentz factor.
  • Another participant challenges the first claim by providing a detailed derivation of dp/du, concluding that it results in m * (γ_u)^3, which contradicts the initial assertion that dp/du equals γ_u * m.
  • A third participant points out that the professor's use of the product rule may have been misinterpreted and suggests that the first term in the professor's expression should be (dγ/dt) * mu, indicating a potential typo.
  • Further discussion raises confusion about the application of the product rule versus the chain rule, with participants questioning why dp/dt should not equal (dp/du) * (du/dt) and why the derivative of γ_u * m is not simply γ_u * m.
  • One participant emphasizes that γ_u is a function of u, which complicates the differentiation process.
Participants express differing views on the correct application of derivatives in the context of relativistic momentum and force. There is no consensus on the correct expression for the force, and the discussion remains unresolved.
Participants highlight the complexity of differentiating expressions involving the Lorentz factor, which depends on velocity, leading to confusion regarding the appropriate mathematical rules to apply.
RagincajunLA
Hey guys, I just had a quiz on relativistic energy and there was a question on there that I was sure I got right but got marked wrong and I think my prof did it wrong. Please tell me what you guys think of this...
The relativistic momentum of a particle traveling with velocity u in frame S is p= γ_u mu where γ_u = (1-(u^2)/(c^2))^-.5. Recalling that the relativistic force is F = dp/dt. What is the best expression for the force in terms of acceleration, the mass, and the lorentz factor γ_u?
OK, so this is how i did it. I said that F = dp/dt = (dp/du)*(du/dt). du/dt is just acceleration, and dp/du is (γ_u)*m, from the above equation. so this means that F = dp/dt = (γ_u)*m*a. Its basically the regular F = ma equation but multiplied by gamma.
My prof said that the answer is F = (d/dγt)*mu + (dm/dt)*γu + (du/dt)*mγ. He said he used chain rule but this doesn't make sense to me at all. I am 100% sure I did it the correct way. Please give me some feed back, I can get an extra 15 pts on my quiz if i can get this right!
How did you get that? If p = mu * (1 - u^2/c^2)^-.5, then by the product rule dp/du = mu * d/du[(1 - u^2/c^2)^-.5] + m * (1 - u^2/c^2)^-.5, and by the chain rule d/du[(1 - u^2/c^2)^-.5] = -0.5 * (1 - u^2/c^2)^-1.5 * -2u/c^2 = (u/c^2) / (1 - u^2/c^2)^1.5. So plugging that back into the product rule equation:
dp/du = [m*(u^2/c^2) / (1 - u^2/c^2)^1.5 ] + [m / (1 - u^2/c^2)^.5 ]
= [m*(u^2/c^2) / (1 - u^2/c^2)^1.5 ] + [m*(1 - u^2/c^2) / (1 - u^2/c^2)^1.5 ]
= m / (1 - u^2/c^2)^1.5
So this would not be equal to m*(γ_u), but rather to m*(γ_u)^3
Incidentally it seems like your prof was using the product rule, not the chain rule (see the part in the opening of the wiki article that says "The derivative of the product of three functions is:")--I assume there's a typo in that first term, and that the first term should actually be (dγ/dt)*mu.
[tex]\frac{d\bf p}{dt}= m\frac{d}{dt}\left[\frac{\bf v}<br /> {\sqrt{1-{\bf v}^2}}\right]<br /> = m[\gamma{\bf a}+\gamma^3{\bf v(v\cdot a)}]<br /> =m\gamma^3[{\bf a}+{\bf v\times(v\times a)}][/tex]
but why use the product rule in the first place? dp/dt should equal (dp/du)*(du/dt). why isn't dp/du equal to γm? isn't it the same thing as taking dy/dx of y=2x? in that case the derivative is just 2. so why isn't the derivative of γmu equal to γm? then you just multiply that by du/dt which is a. that part, ^^^, is what is confusing me...
Because gamma is a function of u.
  • · Replies 29 ·
