Thread Closed
Spectrum Analyzer vs. Network Analyzer
Share Thread Thread Tools
Oct15-04, 03:09 PM   #1
Hi all,
I was wondering if someone could clarify what the difference is between a spectrum analyzer and a network analyzer.
Thanks,
Mike
PhysOrg.com
PhysOrg
engineering news on PhysOrg.com
>> Researchers use light projector and single-pixel detectors to create 3-D images
>> GPS solution provides 3-minute tsunami alerts
>> Single-pixel power: Scientists make 3-D images without a camera
Oct15-04, 09:29 PM   #2
Recognitions:
Gold Membership Gold Member
Homework Helper Homework Help
A spectrum analyzer breaks down a signal into its various frequency components and shows the strength of each component. A pure sine wave will only show a single peak while a distorted/modulated sine wave will show a number of sub peaks.
Network analyzer seems to be a more nebulous term and varies from simple signal/no signal to the ability to check for 'ghost' packets (ie bad termination causes unwanted reflections) With known propagation delay of cabling it can also tell the distance to the problem such as crushed or cut cable.
Oct15-04, 10:46 PM   #3
A vector network analyzer will tell you reflection and transmission coefficients in both directions on a 2 port system. It will also show phase and delay differences between the ports. Both will do their thang over some frequency (or time) range.
Aug23-06, 10:48 AM   #4
Network analyzer measuring a know signal
spectrum analyzer measuring unknown signal
here is a good link
http://eesof.tm.agilent.com/docs/icc...R/SPECTRUM.pdf
Aug24-06, 06:10 PM   #5
A spectrum analyzer is a receiver that scans all frequencies within its range, much like a scanner does.
It then displays the peaks and valleys of a signal during it's frequency sweep.
A network analyzer is a transmitter and a receiver built in one box, which are outputed as coax connections on the front panel, usally N connectors are used.
If you connect the network analyzer through a filter or amplifier, it will show it's frequency response, and calculate numerous parameters of your circuit at hand such as S, Z, Y, h paramers, smith chart and polar plots, phase, group delays, and even inverse fourier transforms which will show you the time domain much like an oscillscope does.
One of the best in the world are made by Agilent, former HP. They are god in the RF community with max frequency ranges up to 325 GHz
Dec3-09, 05:43 AM   #6
Quote by NoTime View Post
Still I am confused that how a spectrum analyzer break down a signal into various frequency Components.
Dec3-09, 12:20 PM   #7
Mentor
Quote by testequipment View Post
(This thread is over 3 years old....)
Here's a tutorial for you:
http://www.spectrum-analyzer.info/Spectrum_Intro.aspx
Dec3-09, 03:20 PM   #8
(wow can't believe it was that long - time goes by so fast)
Basically a spectrum analyzer works just like a radio receiver but with a wider tuning range, and tunes everything automatically.
The key is heterodyning or mixing, which is a process of converting a frequency of a signal to a higher or a lower frequency. To make a mixer work, you need to introduce another signal of some frequency, which is going to be either added or subtracted to the frequency of the incoming signal. Then filter the output which is held constant.
VCO (voltage controlled oscillator) is a circuit that changes frequency with a changing voltage. In the older radios, the VCO was tuned manually with a knob which was actually changing a voltage level on the VCO (in modern radios there is a synthesizer which does this digitally). In spectrum analyzers, the VCO is swept linearly with a ramp voltage and synchronized with the screen - and that gives you the x-axis on graph. To get the y-axis the incoming signal could be up-converted to a higher frequency by adding frequency of the incoming signal to the frequency of the VCO and filtering it out, amplifying and recovering amplitude with a diode....
This is just a basic overview, most spectrum analyzers will have more than 4 mixing stages, gazillion of oscillators, and synthesizers, and filters - that are designed to manipulate the incoming signal by changing its frequency, amplitude, and phase.
Thread Closed
Thread Tools
Similar Threads for: Spectrum Analyzer vs. Network Analyzer
Thread Forum Replies
stereo oscilloscope and spectrum analyzer Engineering, Comp Sci, & Technology Homework 1
LED Spectrum Analyzer schematics Electrical Engineering 11
Spectrum analyzer Electrical Engineering 15
Spectrum analyzer Computing & Technology 9
Spectrum analyzer... General Math 2
