Is {(x,y): x>/0; y>/0} a Vector Space in R^2?
The discussion revolves around determining whether the set {(x,y): x≥0; y≥0} forms a vector space in R². Participants are exploring the definitions and properties of vector spaces, particularly focusing on the axioms that must be satisfied for a subset to qualify as a vector space.
  • Conceptual clarification, Assumption checking, Problem interpretation
  • Participants are attempting to understand the implications of the set's definition and whether it meets the criteria for a vector space by examining specific vectors and scalar multiplication. Questions about the notation used and its standard interpretation are also raised.
There is an ongoing exploration of the axioms related to vector spaces, particularly concerning closure under addition and scalar multiplication. Some participants suggest that the set fails to meet the requirements due to the inability to include certain scalar multiples, while others are clarifying the definitions and implications of the axioms.
Participants are questioning the notation used in the problem statement, specifically the meaning of "x>/0" and its standard interpretation as "x≥0." There is also a focus on the implications of the set not containing the zero vector and the conditions under which it would be considered closed under operations.
012983
Just started learning vector spaces... not as fun as matrices. Anyway, I have a problem here, and I just want to make sure I'm understanding it correctly.
It states: "The set {(x,y): x>/0; y>/0} with the standard operations in R^2." It asks me to prove whether or not it's a vector space.
Does that mean I pick an arbitrary set u, let's say (4,6), and figure out if it forms a vector space using the ten axioms? I don't understand how that point would fit in R^2, so I'm missing something here.
Thanks for any help.
Edit: would it fail under axiom six (cU is in V)? Since if c is a negative number, U would be negative, which wouldn't satisfy the >/ requirement? Or am I learning this incorrectly?
What does this notation - x>/0 - mean?
Is it supposed to say x >= 0? That's the usual notation.
That's neither arbitrary nor a set. That is a specific vector in R2 (i.e., in the plane.
Yes. Assuming you have to verify that all the axioms are true for this set, start with a couple of arbitrary vectors, such as u = <u1, u2> and v = <v1, v2>, and an arbitrary scalar.
Inasmuch as R2 is a vector space and you're dealing with a subset of it, perhaps all you need to do is show that your set is a subspace of R2. In that case, all you need to do is show that 1) <0, 0> is in your set, 2) the set is closed under addition, and 3) the set is closed under scalar multiplication.
I'm not sure what the ">/" requirement is.
Sorry, had a brain fart there and forgot what the standard notation was... indeed I meant >=, or rather ≥.
Could you explain what it means to be closed under addition and scalar multiplication? For the former, does it mean that whenever two vectors within vector space V are added they will fall within vector space V? And similarly for scalar multiplication, that whenever a vector in vector space V is multiplied by a scalar it will fall within vector space V?
Yes. If u and v are in the space, then u + v is also in the space.
Right.
Right.
So if u(4,2) is a vector within R^2, is it not a vector space since (I think) it fails the axiom 'cU is within V?' Given that x>=0 and y>=0 as defined in the problem statement.
A better way to say that is - <4, 2> is a vector in the set, but -1*<4, 2> = <-4, -2> is not in the set, so the set is not closed under scalar multiplication.
Thanks, Mark44. Appreciate all your help.
  • · Replies 19 ·
