Electromagnets and Conductors: The Effects on a Pendulum
  • Thread starter Thread starter XigmaTek
    Electromagnets
The discussion revolves around the effects of a magnet, suspended as a pendulum, when influenced by an electrical conductor nearby. The subject area includes electromagnetism and dynamics of pendulum motion.
  • The original poster attempts to apply Lenz's Law to describe the interaction between the pendulum's magnet and the conductor, questioning the presence of a changing magnetic field. Participants discuss the nature of pendulum motion and the implications of amplitude and period in this context.
Some participants provide clarifications regarding the motion of pendulums and the relationship between amplitude and period. Questions about measurement techniques and the orientation of the magnet's poles are raised, indicating an ongoing exploration of the topic.
There is a mention of the assumption that the pendulum's motion is being analyzed under specific conditions, such as small angles for certain properties to hold true. The original poster seeks further insights into the experimental setup and its implications.
XigmaTek
Question:
Describe what will happen when a magnet suspended in the form of a pendulum is affected by an electrical conductor in close proximity.
My working:
Lenz's Law states that the emf induced in a conductor will oppose the emf of the change that produced it. Let's say I designed my experiment this way...
[PLAIN]http://img191.imageshack.us/img191/562/assessment.png
the dotted line represents the trajectory of the pendulum (should be a perfect parabola shape..)
The magnet moving over the sheet of metal will produce eddy currents in the metal, which will oppose the magnetic field caused by the magnet. Thus, this will cause the pendulum to slow down faster and its period and amplitude will decrease much quicker than if there was no conductor.
Am I correct? What else can be said about this situation? Is there a changing magnetic field present here?
Thank youuuuu!
What you said about the EM is basically correct, but a couple of comments:
(1) Pendulums move on a circular path, not a parabola.
(2) The period of a pendulum is pretty much independent of the amplitude. The amplitude will decrease, but the period will not change.
thanks for that info. but your second point would apply only to small angles.
how would i go about measuring the amplitude?
also, does it matter which end of the magnet (N or S) is facing the sheet of metal as it moves over it?
-You are correct, the period is only independent of amplitude only for small angles.
-To measure the amplitude, you need to measure the maximum deflection. You could take a time exposure picture or a movie and measure it off the picture.
-It doesn't matter whether it is the N or S pole, the effect is the same.
