Magnet which loses its magnetic grip when current passes through
The discussion revolves around the concept of a magnet that loses its magnetic grip when current is applied, exploring potential designs and applications. Participants consider various methods to achieve this effect, including the use of electromagnets, heating elements, and mechanical systems.
  • One participant inquires about the existence of a specific type of magnet or system that releases its grip when current is applied.
  • Another suggests using a rare Earth magnet in conjunction with an electromagnet to cancel or weaken the magnetic field when the current is turned on.
  • A different approach involves heating a permanent magnet, although it is noted that this method is not instantaneous and may lead to permanent demagnetization.
  • One participant proposes using a solenoid to actuate the movement of a permanent magnet, allowing it to retract from the object when energy is applied.
  • Another participant clarifies that heating a magnet does not necessarily lead to permanent demagnetization, citing examples of soldering irons that utilize magnets.
  • A later reply mentions the concept of electropermanent magnets as a potential solution and expresses intent to research available options from manufacturers.
Participants present multiple competing views on how to achieve the desired effect of a magnet that releases its grip with current. There is no consensus on a single solution, and various methods are debated.
Some methods discussed may depend on specific conditions, such as the strength and age of the permanent magnet, as well as the design of the solenoid system. The effectiveness of heating as a method for demagnetization is also not fully resolved.
rowardHoark
Problem
Traditional electromagnets create a magnetic field when current passes through them.
What I need is a magnet that loses its magnetic grip when current passes through.
Is there a particular name for these kind of magnets / systems?
Application
I want the magnet to hold a metal object (no energy should be consumed). With a push of a button (current applied) magnet should release the object.
What about a rare Earth magnet in front of an electromagnet? When you turn on the electromagnet, it is at the reverse polarity of the rare Earth magnet and cancels (or at least weakens) the magnetic field holding the part.
You can do this by heating a permanent magnet with a heating element. It is not instantaneous at all. Another way would be to wind a coil around a bar magnet and appply the current to oppose the bar magnets field (cancellation). As the bar magnet ages and its field weakens you may need to adjust the current.
Doesn't that permanently demagnetize it?
My first thought would be to have a solenoid actuate movement of a permanent magnet, either through direct mechanical motion or pneumatic/hydraulic. Have the permanent magnet retract from the object when energy is applied to the solenoid. Obviously you'd need something for the permanent magnet to retract into/prevent object from following the permanent magnet, but that's just as easily done as setting up any of this.
Edit- We use solenoid valves to apply/remove pneumatic pressure from certain process valves where we need on/off capability instead of precise control.
Heating a magnet does not necessarily permanently demagnetize it. Some weller soldering irons use a magnet in the tip that turns on and off a reed switch. This is what regulates the temp. If you want a different temp just change out the tip.
All the ideas are very interesting.
Heating up the magnet is an original one, however, a combination of a permanent magnet / solenoid seems more elegant.
Further research showed that these are called electropermanent magnets. Here is a short description: http://walkermagnet.com/hagou/magnetic_handling/electro-permanent-magnet.html" .
Will try to contact several magnet manufacturers to see if an off the shelf version is available.
  • · Replies 37 ·
