What is the definition of Lorentz factor?
The Lorentz factor in the context of diffraction theory is defined as the ratio of the integrated intensity of a diffracted beam to the parameters of the experimental setup. Specifically, for a constant-lambda experiment, it is expressed as λ³/sin(2θ) for a Bragg peak from a single crystal. In powder diffraction, the Lorentz factor is modified to λ³/(sin(2θ) * sin(θ)), depending on the detector used. The Lorentz factor is influenced by the sample's geometry, including whether it pertains to the entire polycrystal sample or individual grains.
  • Understanding of diffraction theory and Bragg's law
  • Familiarity with the concepts of integrated intensity and delta-functions
  • Knowledge of polycrystalline materials and their properties
  • Experience with experimental setups in X-ray diffraction
  • Research the mathematical derivation of the Lorentz factor in diffraction contexts
  • Study the impact of detector configurations on Lorentz factor calculations
  • Explore the relationship between grain size and Lorentz factor in polycrystalline samples
  • Learn about the integration of intensity measurements in X-ray diffraction experiments
Researchers in materials science, physicists studying diffraction phenomena, and professionals involved in X-ray crystallography and polycrystalline analysis.
Lojzek
Can anyone explain how Lorentz factor is defined (the one from theory of diffraction,
not special relativity)? I read that intensity of diffracted beam is proportional to
Lorentz factor, but I could not find its definition.
On what parameters does the Lorentz factor depend? How does the Lorentz factor change inside a polycrystal sample? Does it belong to the whole sample, one grain or part of a grain?
Lorentz factor originates from an integration of 3D delta-function (Bragg peak) in certain coordinate system to get the integrated intensity. If we consider constant-lambda experiment then the Lorenz factor will be \lambda^3/\sin(2\theta) for a Bragg peak from a single crystal. Note, the integrated intensity is not just counts/sec, but has the dimension counts*degrees/sec. For the powder case the answer depends on the detector that is used. Additional integration along the Debay cones within some limits given by the detector perpendicular to the scattering plane modifies the Lorentz to be \lambda^3/\sin(2\theta)/\sin(\theta).
  • · Replies 35 ·
28K
