Rotating Fitting for 70 PSI Air Supply at 30000 RPM
  • Thread starter Thread starter DOUGALS69
    Sealing
The discussion focuses on the need for a rotating fitting capable of supplying air at 70 PSI through a 60mm diameter shaft rotating at 30,000 RPM. The user seeks advice on suitable fittings that can be threaded into the shaft's end for air supply attachment. A labyrinth seal is suggested as a potential solution to maintain pressure integrity during operation. The feasibility of this setup is confirmed, emphasizing the importance of selecting the right components for high-speed applications.
  • Understanding of rotating fittings and their applications
  • Knowledge of pneumatic systems and air pressure requirements
  • Familiarity with labyrinth seals and their function in sealing
  • Experience with high-speed rotating machinery
  • Research suitable rotating fittings for high-pressure applications
  • Explore the design and implementation of labyrinth seals
  • Investigate materials compatible with 70 PSI air supply at high RPM
  • Learn about the dynamics of air flow in rotating shafts
Mechanical engineers, designers of pneumatic systems, and anyone involved in high-speed rotating machinery applications will benefit from this discussion.
DOUGALS69
I am currently looking to push air through a middle hole in a 60mm dia shaft traveling at 30000 Rpm, the pressure i require is 70 PSI. I am looking for a rotating fitting that can be threaded into the end so the air supply can be attached. Can someone point me in the right direction or tell me if this is possible please? I know its a liitle vague but any help would be much appreciated.
Consider a labyrinth seal.
  • · Replies 45 ·
