What is the coefficient of friction and weight of the block?
  • Thread starter Thread starter kimikims
    Coefficient
The problem involves determining the coefficient of friction for a block weighing 5.3 N that requires a force of 3.2 N to move at constant velocity. Additionally, the problem asks for the weight of an added mass W when a total force of 6.6 N is needed to maintain constant velocity with the block and the weight together.
  • Participants discuss the use of equations related to friction and normal force, with some suggesting the drawing of a free-body diagram. Questions arise regarding the forces acting on the block and the implications of constant velocity on those forces.
Some participants have provided insights into the relationship between applied force, friction, and normal force, while others express confusion about the explanations given. There is an ongoing exploration of the forces involved and how they relate to the coefficient of friction.
Participants note that the block is in equilibrium since it moves at constant velocity, which implies that the sum of forces acting on it is zero. There is also mention of needing to clarify any angles involved in the setup.
kimikims
Can anyone help me with this problem? What equations should I use?
A block weighing 5.3 N requires a force of
3.2 N to push it along at constant velocity.
What is the coefficient of friction for the
surface?
A weight W is now placed on the block and
6.6 N is needed to push them both at constant
velocity. What is the weight W of the block?
Answer in units of N.
Fk=Ukn so Fk/n=Uk where Fk is the force and n is the normal force... draw a free-body diagram and do the equations to solve for it... Help any? Also, the crate is in equilibrium since it moves at constant velocity... Any angles involved?
I'm sorry... that doesn't make any sense to me.
Since you know the block is moving at constant velocity, the sum of all forces on it must be zero...otherwise it would be accelerating. So what are the forces in the horizontal direction? Wel,, there are only two: the one that you are applying to move it [tex]F_{push}[/tex] and the force of kinetic friction [tex]F_k[/tex]. You can then use the definition of kinetic friction: [tex]F_k = \mu_k N[/tex] here [tex]N[/tex] is the normal force on the box. Of course the normal force is simply the weight of the box in this case. Plug the stuff into [tex]\Sigma F = ma = 0[/tex] and solve for [tex]\mu_k[/tex]. For the second part of the problem you will have to use the value of [tex]\mu_k[/tex] that you just found.
  • · Replies 16 ·
  • · Replies 28 ·
