Question about nuclear cross sections
  • Context: Graduate
  • Thread starter Thread starter coregis
    Cross Nuclear
The overall cross section for the reactions Co-59(n,p)Co60metastable and Co-59(n,p)Co60ground is definitively calculated as 37 barn, derived from the sum of the individual cross sections of 19 barn and 18 barn, respectively. These reactions are mutually exclusive, meaning the total probability of producing Co60, whether in metastable or ground state, is the sum of both cross sections. The concept of cross sections serves as a normalized probability, and it is essential to understand that they represent effective interaction areas rather than physical surfaces.
  • Understanding of nuclear reactions and cross sections
  • Familiarity with neutron interactions in nuclear physics
  • Basic knowledge of probability theory as it applies to nuclear events
  • Awareness of the concept of metastable states in nuclear decay
  • Research the concept of nuclear cross sections in detail
  • Learn about the statistical interpretation of nuclear reactions
  • Explore the differences between ground state and metastable state isotopes
  • Investigate the role of neutron flux in nuclear physics experiments
Students and professionals in nuclear physics, particularly those studying neutron interactions and cross section calculations, will benefit from this discussion.
coregis
This is a small part of a homework problem in which I need to calculate neutron flux. I have the neutron beam hitting a copper target, and two reactions take place Co-59(n,p)Co60metastable (cross section=19barn) and Co-59(n,p)Co60ground (cs=18barn). What is the cross section overall? Do I simply say there is a 18+19=37 barn cross section overall? I'm not so sure, it makes sense to add them thinking about it from a probability standpoint, but from an area of target standpoint, I think it should be somewhere between 18 and 19. Any thoughts? Thanks.
It is simply the sum, almost by definition. The first cross section is a normalized way of giving the probability that a neutron plus Co59 will give you a metastable Co60. The second one is the probability that the neutron plus Co59 will give you a ground state Co60. These events are mutually exclusive of course, so the probability of obtaining Co60 (metastable or ground state) is the sum of both. In fact, the cross sections have been SPLIT UP in 18 and 19: the total cross section Co59->Co60 is 37 barn, and that has been refined in a fraction metastable and another fraction groundstate.
I think I see where you are having an issue, in that "the surface taken to interact with the neutron is 18 for one interaction, and 19 for another one, so I'd have a weighted surface for both". No, think of the Co59 nucleus as having a surface of 37 barn, and if you hit the upper 19 barn of it, you'll have a metastable state, and if you hit the lower 18 barn, you'll have a ground state. But then be carefull with this picture :smile: After all, it is a PICTURE, because cross sections are nothing else but normalized probabilities.
cheers,
Patrick.
Thanks so much, you reply helped me see what I had suspected. Now on to bigger and more confusing problems...
