Chalkboards or Whiteboards: Which is Better for Clear Understanding?
  • Thread starter Thread starter gazzo
The discussion revolves around the advantages and disadvantages of using chalkboards versus whiteboards for studying and problem-solving in physics and mathematics. Participants share personal experiences, preferences, and practical considerations regarding both types of boards.
  • Meta-discussion
  • Some participants express a preference for larger writing surfaces, suggesting that chalkboards or large sketch pads allow for better visibility and understanding of complex problems.
  • Others mention the practicality of using whiteboards, noting their cleanliness and aesthetic appeal compared to chalkboards, which can create dust.
  • A participant shares a method of creating a chalkboard surface using spray paint, highlighting the versatility of chalkboards.
  • Concerns about the size of boards are raised, with participants noting that smaller boards may not be sufficient for extensive problem-solving.
  • Some participants discuss the availability and cost of whiteboards, indicating that prices can vary significantly based on size and quality.
  • Experiences with using dustless chalk on chalkboards are shared, with some participants noting that it helps mitigate dust issues.
  • There is mention of alternative surfaces, such as tables with whiteboard tops in engineering workplaces, which some find enjoyable for collaborative work.
  • Discussion includes the use of grease pencils on glass surfaces, with mixed opinions on their practicality and effectiveness.
  • Historical anecdotes about famous mathematicians using slates and unconventional methods for writing and erasing are shared, illustrating diverse approaches to problem-solving.
Participants do not reach a consensus on which type of board is superior, as preferences vary widely based on individual experiences and needs. Multiple competing views remain regarding the practicality, usability, and aesthetic aspects of chalkboards versus whiteboards.
Limitations include varying personal preferences, potential biases based on individual experiences, and the subjective nature of usability and effectiveness of each board type.
Individuals interested in studying techniques, educators considering classroom tools, and anyone looking for effective ways to visualize complex problems in STEM fields may find this discussion relevant.
gazzo
Hmmm,
I need to write things big where i can see them as a whole in order to understand them properly. :cry: I was thinking about buyin a cheap chalkboard second hand, do you people use them ?
Or whiteboards even.
Bah.
Not a bad idea. I sometimes squat a classroom if I want to work on something, so that I can use the blackboard. Usually, in the late afternoon, half the lecture rooms are unused, so I can use them at my discretion :wink:
I read somewhere that this physicist would get those huge sketch pads that artists uses and does his math in those. I thought about getting one myself.
I got myself a whiteboard in my room. I'll get a pic sometime and show you.
It is the same size as those in lecture halls/classrooms. I wouldn't recommend a chalkboard because they create lots of dust.
Also, don't settle for a 2 by 3 feet board. They might seem big, but they aren't. You can barely fit much onto it. I got one, but then I realized this, so I got a huge one.
Note: Mother works at the schoolboard, so I got it for cheap.
EDIT: Or do what Dimitri said. Most schools have study rooms that come with them to. Hell why not go to the local high school and ask them if you chill out over there.
blackboards are awesome to work on, if the chalk doesn't squeak.
Chalkboards and whiteboards are both great. When I was in college, we had both available, each of the kitchens had a whiteboard (one kitchen per floor) and the lounges had chalkboards on wheels. It was great to go work out a problem on those when you were really stumped with a chunky math problem. They were also great for working in study groups to work through problems together.
Whiteboards are less dusty, and I think look better, but you can make a cheap chalkboard - they sell spraypaint in most home hardware type stores that is for making a chalkboard right on your wall. Just tape off the area where you want a chalkboard and paint inside. You could probably put a border around it if you wanted it to look nicer, but if you're just looking for cheap and functional, no need.
JasonRox is right,
I have a 2ft x 3ft whiteboard in my room. Was going to use it for solving physics problems and such. Seemed like a good idea at the time...but it is a little too small.
Oh, if you're getting lots of direct sunlight on the whiteboard, make sure you erase it often otherwise the marker gets stuck on and you need to scrub the hell out of it to get it off.
When my college was replacing all the chalkboards with whiteboards, I was able to pick up a full 16 foot long chalkboard (with chalkrails included) for free. Since then, I've divided the chalkboard into 3 segments to make it more manageable in my room. Usually, when I work a complex problem, I'll do it on the chalkboard. Works pretty nicely.
16 feet! crikey!
dosn't the dust get to you?
gazzo said:
16 feet! crikey!
It's not too bad. I've always used dustless chalk, and it works rather well. The main thing with a chalkboard is to not wipe the board with your fingers or anything else for that matter - you need to only touch it with the chalk or an eraser. Otherwise, oil could build up on the board and make it hard to clean, and the dust can be stirred up.
I was just looking up whiteboards on ebay. Damn, are these thing expensive or what ! :eek:
That's why you need to know people.
Mine is pretty big. 6 x 4 feet.
It has a marker rail or whatever you call it too. It's not a cheap board that bends too. Once it is installed, it is installed.
I use my 3 x 2 when I do work on my bed. I set it next to myself so I can do a bunch of problems while not wasting paper. I also use a pen style marker so it doesn't take much space.
The other thing that's good is that I do my homework on it. Once I get it, I write it down neatly on paper. It looks like I solved it with no problems! :bugeye:
I need to get me one of each those...or five of the 3x2 which would be exactly the same amount of whiteboard space...*plans shopping trip*
edit: OMG...$100 for a 3x2...am i looking at the wrong place or something?
http://www.whiteboardsetc.com/ProRiteMagneticMarkerboard.htm [/URL]
http://www.whiteboardsetc.com/ProRiteMagneticMarkerboard.htm [/URL][/QUOTE]
Holy crap! Well, I got my 3x2 from Staples/Business Depot. Including a set of 4 markers and an eraser, I think it came to a total of around $40 Canadian, so ~$30 USD. That's not so bad.
~$30-40.
To get one that is bigger, well the price goes up fast. For a 6-4 feet, regular price is anywhere from $300-500.
Dang. I still say to get a huge sketch pad that artists use instead.
I didn't pay anywhere that price, but whatever floats your boat.
I probably saved so much paper. I can't imagine how much paper I saved.
Many engineering workplaces have tables with whiteboard tops. The tables are about 4 feet in diameter, and the entire top is one big whiteboard. I love them! It kinda makes me feel like a kid again, scrawling all over the desk.
- Warren
The green surface of a chalkboard is actually a paint. YOu can find this paint at many "big box" stores like Home Despot. School chalkboards are painted onto steel, but you can paint on wood. Trouble is in getting a smooth surface.
BTW, does anyone use grease pencils on glass? or is this only done in movies? (Good Will Hunting, Beautiful Mind, eg)
It also works well on metal, like stainless steel.
The only problem with glass is that you see through it. It would give you a headache after awhile.
If you want to impress people with your "high-tech" room, use the grease pencil and glass.
Not to mention the pencils/lead that you could save, also. When I started doing math seriously, I've used nothing but mechanical pencils. I love those things!
One of my professors, in his office, has a small dry erase board. I've never seen him use it, but there's always something on there.
Did anyone ever read the biography of Ramanujan? It's called The Man who knew Infinity, and it describes how, in his teens, he would sit on the front porch of his family home with three slates in his lap. He had taught himself to erase with his elbow so he didn't have to stop his math writing to do that. He worked with an old second rate do-it-yourself higher math book from England, and developed past it by doing the math on those slates.
Sounds like an interesting book. I should probably check it out.
Let me think:
100 sheets of paper (x 10, for 1000 sheets) + a pencil + eraser = $5
6x4 whiteboard = $200
Hm... let's see... tough decision
deltabourne said:
Let me think:
A mess... no mess.
Hmm... let's see.
A pile of paper to remind you that it took you this many papers to complete a simple problem.
A blank whiteboard to remind you that you did the question in your head instantaneously as you read the question. :biggrin:
At least this way you'll never go cold. :biggrin:
  • · Replies 17 ·
