A 10 lb block is attached to unstretched spring
  • Thread starter Thread starter Ryan1059
    Block Spring
The problem involves a 10 lb block attached to an unstretched spring with a spring constant of 12 lb/in, and it explores the dynamics of the block when a force is applied and then removed. The context includes considerations of static and kinetic friction coefficients, as well as energy principles related to springs and motion.
  • The original poster attempts to determine the maximum speed of the block after a force is applied and removed, having already calculated the speed as it returns to its initial position. Participants discuss the relationship between forces and acceleration, and the implications of instantaneous acceleration on maximum velocity.
Participants are engaging in a back-and-forth dialogue, with some providing guidance on the relationship between forces and acceleration. There is an exploration of relevant equations and concepts, but no consensus has been reached on the method for calculating maximum speed.
There is mention of the need to correct an equation related to Hooke's Law, and participants are navigating the complexities of setting up equations without delving deeply into calculus. The original poster expresses uncertainty about how to begin solving for maximum speed.
Ryan1059
A 10-lb block is attached to an unstretched spring of constant k=12lb/in. The coefficients of static and kinetic friction between the block and the plane are 0.60 and 0.40, respectively. If a force F is slowly applied to the block until the tension in the spring reaches 20lb and then suddenly removed, determine (a) the speed of the block as it returns to its initial position, (b) the maximum speed achieved by the block
F=-k/x
Ff=mew(Fn)
Espring = 1/2kx(squared)
KE = 1/2mv(squared)
this is first post so I don't really know proper format for equations
I solved for Velocity in returning position, I got an answer of 2.32 ft/sec which is correct according to my books answer key.
I really just need help with solving for V max. I realize that I should go about setting up an equation that sets KE equal to X and then solve for KE max, but I don't know how to begin. Please help, any direction would be appreciated.
:smile:Hi, Ryan, welcome to Physics Forums!:smile:
If you are familiar with calculus, instantaneous acceleration is defined as the slope of the V-t curve, dV/dt, which indicates a maximum velocity occirs when the slope of the V-t curve is zero, that is, when the instantaneous acceleration is 0. Now when the instantaneous acceleration is 0, what can you say about the forces acting on the block at that point?
thank you anyways for responding! and putting up with the god awful equations i set up haha. alright well if there is no instantaneous acceleration then that means there are no forces acting on the block. It makes enough sense. I would think that I should take the derivative of some function of velocity, solve for zero which would give me my max velocity, correct? But I don't know how to set up the equation or anything or where to start.
You've got to first correct your first relevant equation , Hooke's Law, which is F = -kx.
Then the point of 0 acceleration in the x direction is the point where there are no NET forces acting in the x direction. There are actually 2 forces acting... which two? Their sum must add to zero... and the max speed can be calculated in the same manner in which you calculated (or I think you calculated, no work was shown) the answer to part a. You don't want to get into any more calculus than you have to.:biggrin:
