Capacitor and 1 British Pound MAGNET
  • Context: Undergrad
  • Thread starter Thread starter babushka
    Capacitor Magnet
The discussion centers on the phenomenon observed when a capacitor is connected to a DC supply with a 1 British Pound coin placed in parallel. When the circuit is completed, significant instantaneous currents flow from the capacitor, causing the supply to heat up and the wires to exhibit magnetic properties strong enough to lift the coin. This effect is due to the shorting of current through the coin, leading to a rapid increase in temperature and the welding of the coin to the wires, rather than true magnetism.
  • Understanding of capacitor behavior in DC circuits
  • Knowledge of electrical resistance and Ohm's Law
  • Familiarity with the concepts of current and voltage
  • Basic principles of electromagnetism
  • Research the effects of high instantaneous currents in capacitors
  • Learn about the thermal dynamics of power supplies under load
  • Explore the principles of electromagnetic induction
  • Investigate the process of welding metals using electrical currents
Electronics enthusiasts, electrical engineers, and students studying circuit theory and electromagnetism will benefit from this discussion.
babushka
Hi guys. I've got an interesting questions. I found it tricky maybe somebody knows the answer. When I attach to DC supply a capacitor with a coin 1 British Pound parallel to the capacitor and connected by two wires coming out of the capacitor, I always get kind of sparkles in my coin, the supply gets hot and suddenly these two wires from the capacitor become a magnet which can easily lift my pound up as a real magnet. Explain it please.
It appears you are shorting the current from the power supply and capacitor through the coin. You can get quite large instantaneous currents out of a capacitor. The "magnetic force" you see is not actually magnetism. You have simply welded the coin to the wires.
The supply is getting hot because you are dissipating most of the energy from the supply inside the supply itself as the internal resistance of the supply is much larger than the coin. Power is current squared times resistance. The coin has a rather small resistance.
BoB
  • · Replies 18 ·
  • · Replies 27 ·
