Data comparison and noise measurement
The discussion revolves around measuring signal noise in a TV cable after introducing a splitter and comparing it to the original signal. Participants explore the appropriate instruments for this measurement, including oscilloscopes and amplifiers, while considering various factors such as bandwidth frequency and types of noise.
  • One participant suggests using a Digital Storage Oscilloscope (DSO) for measuring noise, noting the importance of bandwidth and the potential costs associated with high-frequency scopes.
  • Another participant expresses a desire to measure the Signal-to-Noise Ratio (SNR) of their homemade device after a cable splitter, indicating an interest in practical applications of the measurement.
  • A different participant argues that a spectrum analyzer is more suitable for properly measuring noise compared to a DSO, emphasizing the complexity of noise measurements and the need for specific knowledge and tools.
  • Questions are raised about the type of noise to be measured, such as phase noise versus SNR, and the potential for distortion when adding an amplifier to the setup.
  • Concerns are mentioned regarding the noise created by splicing cables and the adequacy of existing literature on the subject, which may be too advanced for the participants' current needs.
Participants express differing opinions on the best instruments for measuring noise, with some advocating for DSOs and others for spectrum analyzers. There is no consensus on the specific type of noise to measure or the implications of using an amplifier.
Participants acknowledge the complexity of noise measurements and the need for appropriate tools and knowledge, but specific assumptions and definitions regarding noise types and measurement techniques remain unresolved.
This discussion may be useful for hobbyists and professionals interested in signal processing, electronics, and noise measurement techniques, particularly in the context of TV cable systems.
taupune
Hi,
I would like to measure the signal noise in a tv cable after introducing a splitter and compare it with the original signal.
Keeping in mind the bandwidth frequency of the tv cable signal transmission, what kind of instrument do I need? Oscilloscope perhaps? At what speed? I don't know yet the cable info, but I am searching for it and trying to make sense out of all that jargon.
Thank you
taupune,
Yes, a DSO (Digital Storage Oscilloscope) would be the right answer. For a "good test", you will need a two channel DSO. Depending on the frequency range you are interested in this may be a rather serious investment. A DSO capable of accurately analyzing noise in a 7mhz to 1Ghz signal is a fairly high-tech piece of equipment. Lecroy makes some nice scopes in the > 1Ghz frequency range, and they are everything except cheap. If you are only interested in the lower frequency channels, there are some very decent scopes available for orders of magnitude less money. You can find fairly decent DSO's with bandwidths < 100mhz for less than $1000usd. To get > 1Ghz scopes you are looking @ $20k+.
While I think a DSO is an essential part of a good hobbyist's tool kit, looking @ analog or digital cable signals is pretty mind-numbing unless you have some specific purpose in mind. It might be a good idea to simply state what you are attempting to do (If you want the SNR of a cable splitter, it should be plainly written on the package, or available from the MFG, so I am assuming this is NOT what you are truly after.)
Fish
I want to put an amplifier right after the cable splitter and see what will I get. Will I get better signal compared to the datasheet or no.
I checked on digikey and they had opamp in the commercial amplifiers for only a few bucks.
So yeah, I want the SNR but of my own homemade device.
I will see if I can find ony digital storage oscilloscope laying around my basement ( I meant school labs :) )
This is the type of measurement that can be as difficult or as "easy" as you want. You can't use a DSO to "properly" measure noise, for that one usually uses a spectrum analyser. You also have to decide what "kind" of noise you want to measure (phase noise? Or are you looking for the SNR)), another important parameter is the distortion.
Noise measurements are very tricky, and in order to do it properly you need the right tools and quite a bit of knowledge.
What type of noise is created by adding two cables together with a splicer?
I think I need SNR, don't I?
I have been reading a book about cables but its really deep and thick one. it can be probably used for graduate studies. There is too much info in it.
If i put an amplifier would it create any phase distortion?
Thank you f95toli.
  • · Replies 24 ·
  • · Replies 0 ·
