Ski-Tow question - Work and Power
  • Thread starter Thread starter sinisterlink
    Power Work
The power required to operate a ski tow on a slope of 15.5 degrees and a length of 290 meters is estimated to be 1065 watts. This calculation is based on the total weight of 50 riders, each averaging 75 kg, resulting in a combined weight of 3750 kg. The work done is calculated using the vertical distance derived from the slope, approximately 75.2 meters, leading to a total work of 281400 joules. The speed of the tow, at 11.5 km/h (approximately 3.19 m/s), is used to determine the time taken, which is essential for calculating power using the formula P = W/t.
  • Understanding of basic physics concepts, particularly work and power.
  • Familiarity with trigonometry for calculating vertical distances from slopes.
  • Knowledge of unit conversions, specifically from kilometers per hour to meters per second.
  • Ability to perform calculations involving mass, weight, and force.
  • Study the formula for power, P = W/t, in greater detail.
  • Learn about the principles of work and energy in physics.
  • Explore trigonometric functions and their applications in real-world scenarios.
  • Investigate the effects of slope angles on mechanical systems.
This discussion is beneficial for physics students, engineers, and anyone interested in understanding the mechanics of ski tows and power calculations in practical applications.
sinisterlink
A ski tow operates on a slope of angle 15.5 degrees of length 290m . The rope moves at a speed of 11.5km/hr and provides power for 50.0 riders at one time, with an average mass per rider of 75.0kg .
Q: Estimate the power required to operate the tow.
I missed class when he went over power.
i drew a free body diagram already but I am still lost. I need someone to point me in the right direction.
nevermind i got it
A: Hi there, it looks like you are trying to calculate the power required to operate the ski tow. To do this, we need to use the formula for power, which is P = W/t, where P is power in watts, W is work in joules, and t is time in seconds. In this case, we can estimate the work by multiplying the force (which is equal to the weight of the riders) by the distance traveled. Since we have 50 riders with an average mass of 75kg, the total weight would be 50 x 75 = 3750kg. We can then find the work by multiplying this weight by the vertical distance traveled, which is given by the slope of 15.5 degrees and the length of 290m. We can use basic trigonometry to calculate the vertical distance, which is approximately 75.2m. So, the work would be 3750 x 75.2 = 281400 joules. Now, we just need to convert the speed of 11.5km/h to m/s, which is approximately 3.19 m/s. Finally, we can calculate the power by dividing the work by the time, which would be 281400 / (290/3.19) = 1065 watts. Therefore, the estimated power required to operate the ski tow would be 1065 watts. I hope this helps and points you in the right direction!
16K
12K
10K
11K
24K
