How can the window washer move at constant velocity with unbalanced forces?
The discussion revolves around a window washer using a pulley system to raise himself at a constant velocity. The problem involves analyzing the forces acting on the washer and the bucket, specifically focusing on the conditions for constant velocity in the presence of unbalanced forces.
  • Participants explore the relationship between the forces acting on the washer and the bucket, questioning how constant velocity can be achieved despite unbalanced forces. There are discussions about the implications of net force being zero and the interpretation of forces in different directions.
Participants are actively engaging with the concepts, with some clarifying the conditions under which the washer can move at constant velocity. There is a recognition that if the net force is zero, the system can either be at rest or moving at constant velocity, though confusion remains regarding the application of forces and coordinate systems.
There are indications of confusion around the definitions of forces acting in different directions and the choice of coordinate axes, which may affect participants' understanding of the problem setup.
ThomasMagnus
A window washer pulls himself upward using the bucket pulley apparatus shown. How hard must he pull downward to raise himself at a constant speed? The mass of the person and the bucket is 65kg.
My attempt:
When doing pulley problems, I like to set 'moving to the right' as positive. In this case, there are two forces acting toward the right side and one to the left.
The force that the washer pulls with will be equal to the force that the rope applies on the bucket
The forces acting on the bucket: FT-mg=0 (constant acceleration therefore a=0)
Forces acting on the right side: FT=0
Add the two equation together:
2FT=mg
mg=637N
FT=319N
My question is: How can he be moving at constant velocity if there is an unbalanced force acting on the right side? Is it because there is no net force acting on him? (i.e FT-mg=0) If he is moving at constant velocity, can there be a net force on one side of the pulley, but not on another. Or if he is moving at constant velocity, does there have to be a net force of zero on the entire system?
If the sum of the forces acting on the washer and bucket is zero, then is he at rest or is he moving at constant velocity? My guess is if the forces are balance on the bucket, then he will move at constant velocity because of the force he is applying on the other side of the rope (other wise he would be at rest)
Thanks!
In order for the man to move at constant velocity the net force on him must be zero. He can't move at a constant velocity if there is an unbalanced force on the right (think about it: the right side of the rope would accelerate but the left side wouldn't? would the rope not rip in this case?). If the man doesn't apply a force to the right side would he accelerate? If so, in which direction?
Hi ThomasMagnus! :smile:
ThomasMagnus said:
2FT=mg
mg=637N
FT=319N
This is correct, but I have no idea what you mean by forces acting towards the right. :confused:
The free body diagram for washer-and-bucket has only three forces, all vertical: two equal tension forces upward, and the weight downward.
Since the acceleration is zero, 2T = mg.
Yes. :smile:
Either.
Where I was getting mixed up is with the coordinate axis. Should I choose any forces that will act in the direction of the acceleration (or in this case motion) to be positive?
Thanks
Hi ThomasMagnus! :wink:
(just got up :zzz: …)
You can do either … since the acceleration in this case is zero, it doesn't matter. :smile:
(Usually, it's easier to use the direction in which the acceleration is positive, so that your F = ma equation has both sides positive instead of negative! :biggrin:)
2FT=mg
mg=637N
FT=319N
You first say that FT=0 and then say FT=319N.
This does not make any sense.
Also do you mean upward direction as right?
  • · Replies 18 ·
9K
13K
  • · Replies 62 ·
