Question about the integral test
The discussion revolves around the evaluation of the series (∞, n=1) ∑ ne-n using the integral test to determine its convergence or divergence. Participants explore the application of integration by parts to evaluate the corresponding integral.
  • Participants discuss the use of integration by parts and the proper evaluation of limits in the context of definite integrals. There are questions about the intent behind using the integral test versus other methods like the ratio test.
The discussion includes attempts to clarify the steps involved in applying integration by parts and the evaluation of limits. Some participants suggest alternative methods for checking convergence, while others focus on the integral test approach. There is ongoing exploration of the implications of the limits and the convergence of the series.
Some participants note that they have not yet learned the ratio test, which influences their choice of method for evaluating the series.
vande060
(∞, n=1) ∑ ne-n
(∞, n=1) ∑ ne-n
limt--> ∞ ∫ xe-x dx from 1 to t
here i tried to do integration by parts
u = x
du=dx
dv= e-x dx
v= -e-x
not sure where to take limits at this point, is it like this
limt--> ∞ -xe-x (from 1 to t) + limt--> ∞ ∫ e-xdx from 1 to ti can of course go further with the integral, but how does this look so far, i can't really make sense out of it :/
You forgot to say what you are actually trying to do. Are you trying to sum the series or just show it converges?
When evaluating a definite integral using integration by parts, evaluate it as if it were an indefinite integral and then substitute your limits over the entire integrand.
oops use the integral test to determine whether the series is convergent or divergent
so ill try just taking the integral by parts, then apply the limit with where i end up over the entire integrand in that process like this?
I = ∫ xe-x dx from 1 to t
u = x
du=dx
dv= e-x dx
v= -e-xI = -xe-x (from 1 to t) + ∫ e-x dx (from 1 to t)
I = -xe-x (from 1 to t) -e-x + C (from 1 to t)
I = lim t --> ∞ -xe-x (from 1 to t) - lim t --> ∞ e-x + C (from 1 to t)
Ok, then. You know the integral converges, right? Now you just have to show lim x->infinity of x*e^(-x) exists.
Basically, yes. Substitute your upper and lower limits into the integrand, and then take [tex]\lim_{t \to \infty}[/tex].
Checking convergence by doing a much simpler ratio test wouldn't hurt you a bit either. I don't know why you are doing an integral test on this one. Was that your choice?
no choice, have not learned ration test yet, that's next chapter
Basically, yes. Substitute your upper and lower limits into the integrand, and then take lim
okedokie, so to wrap this up:
I = lim t --> ∞ -xe-x (from 1 to t) - lim t --> ∞ e-x[/SUBP] + C (from 1 to t)
Ill break it into 2 pieces:
lim t --> ∞ -xe-x (from 1 to t) = -(0-1/e) = 1/e
- lim t --> ∞ e-x[/SUBP] + C (from 1 to t) = ( 0 - 1/e) = -1/e
so the answer is that the series converges on 2/e
The ratio test states that, for a series [tex]\sum_{n=0}^\infty a_n[/tex], for [tex]L = \lim_{n \to \infty} \left| \frac{a_{n+1}}{a_n} \right|[/tex]:
if L > 1, the series diverges.
if L = 1 or DNE, the test fails
if L < 1, the series converges absolutely.
Yes, so substitute the limits in, take the limit as t > infinity, and what do you get? Note that the integral is definite so there is no need for C.
vande060 said:
Ill break it into 2 peices, starting with the second piece
- lim t --> ∞ e-x[/SUBP] + C (from 1 to t) this should go to 0
You'll want to substitute in the limits of integration first, so you have:
[tex]\lim_{t \to \infty} \left[\left(-te^{-t}-e^{-t}\right)-\left(-e^{-1}-e^{-1}\right)\right][/tex]
Yes.
  • · Replies 22 ·
  • · Replies 16 ·
