New Reply
Sinusoidal Graph - sub intervals
Share Thread
Mar16-11, 02:13 AM   #1
I can find the graphs amp and period. The only problem is finding the sub points or sub intervals. Say...
Y = 3 sin (4x)
Amp = 3
Period = 2pi/4 = pi/2
But.. don't know how to get the key points of the sub interval. The text book says I have to divide interval [0, pi/2] into four sub intervals Each of length pi/2 divided by 4. Then they got (0,0), (pi/8, 3), (pi/4, 0), (3pi/8, -3), (pi/2, 0) I don't understand how they got these. Thanks
2. Relevant equations
3. The attempt at a solution
PhysOrg.com science news on PhysOrg.com
>> New language discovery reveals linguistic insights
>> US official: Solar plane to help ground energy use (Update)
>> Four microphones, computer algorithm enough to produce 3-D model of simple, convex room
Mar16-11, 02:38 AM   #2
Recognitions:
Homework Helper Homework Help
Draw the base graph y=sin(x) with [itex]0\leq x\leq 2\pi[/itex], It has a value of 0 at [itex]x=0,\pi,2\pi[/itex] and a value of 1 and -1 at [itex]x=\pi/2, 3\pi/2[/itex] respectively.
Basically, every sine graph of the form [itex]y=Asin(Bx)[/itex] will still have this same shape, but the amplitude (A) and period (B) will be different from the base graph y=sin(x).
What you should take away from this is that if the period of sin(x) is [itex]2\pi[/itex], then in between the two ends of the period 0 and [itex]2\pi[/itex] which is [itex]\pi[/itex], it will also be 0, and in between 0 and its half way mark which is [itex]\pi[/itex] we get the value of its amplitude (in this case 1), and between the half way mark and the end, [itex]\pi[/itex] and [itex]2\pi[/itex] we get the negative of its amplitude, -1.
Mar16-11, 03:30 AM   #3
Quote by Mentallic View Post
Thanks, I know that but I don't know how to get the points in between the sin graph
I know if period = 2 pi then the middle point would me pi, but what if it has a different period. I don't know what to label on the graph on the middle part.
Mar16-11, 03:51 AM   #4
Recognitions:
If the period is [itex]2\pi[/itex] then middle is half of that [tex]\frac{2\pi}{2}=\pi[/tex]. If the period is some number x then the middle is x/2.
Mar16-11, 04:23 AM   #5
Ahhh I see now. Thank you my friend.
Mar16-11, 04:55 AM   #6
Recognitions:
Good luck!
New Reply
Similar discussions for: Sinusoidal Graph - sub intervals
Thread Forum Replies
Graph of a sinusoidal wave at a fixed position Introductory Physics Homework 2
intervals of increase and the intervals of decrease? Introductory Physics Homework 3
how to do velocity-time graph to distance graph/acceleration to velocity graph? Classical Physics 1
manipulating inverse square graph into straight line graph Introductory Physics Homework 4
Real life situation to a sin graph on position by time graph Differential Equations 6
