Conservation of linear momentum stationary block
The discussion focuses on solving a problem involving the conservation of linear momentum and the work-energy theorem after a stationary block explodes into two pieces, L and R. The mass of piece L is 2.4 kg, with a coefficient of kinetic friction µL = 0.40, stopping after sliding 0.15 m, while piece R has a coefficient of kinetic friction µR = 0.50 and stops after sliding 0.34 m. The initial momentum of the block must equal the sum of the momenta of the two pieces, leading to the equations derived from the work-energy theorem, which relate the change in kinetic energy to the work done by friction. The calculations must be carefully executed to find the mass of the original block.
  • Understanding of conservation of linear momentum
  • Familiarity with the work-energy theorem
  • Knowledge of kinetic friction coefficients
  • Ability to solve algebraic equations
  • Calculate the initial velocities of pieces L and R using the work-energy theorem
  • Apply conservation of momentum to find the mass of the original block
  • Explore the relationship between friction and motion in explosive scenarios
  • Review examples of similar physics problems involving explosions and momentum
Physics students, educators, and anyone studying mechanics, particularly those interested in momentum conservation and energy transformations in explosive events.
skaring
I have been trying and trying to get this problem. I am using the fact that delta K = Fd, I set 0= to Fd of one part + Fd to the other part, and it is not the correct answer.
In Figure 9-57, a stationary block explodes into two pieces L and R that slide across a frictionless floor and then into regions with friction, where they stop. Piece L, with a mass of 2.4 kg, encounters a coefficient of kinetic friction µL = 0.40 and slides to a stop in distance dL = 0.15 m. Piece R encounters a coefficient of kinetic friction µR = 0.50 and slides to a stop in distance dR = 0.34 m. What was the mass of the original block?
It sounds like you are trying to apply conservation of energy. But energy is not conserved--the block exploded!
But you can use [itex]\Delta KE = Fd[/itex] for each piece to find the initial speeds of the two pieces just after the explosion. Do that and then use conservation of momentum to analyze the explosion itself.
It seems like you have the right idea by using the conservation of linear momentum and the work-energy theorem, but there may be some mistakes in your calculations. Let's take a closer look at the problem.
First, let's define some variables:
m = mass of the original block
v = velocity of the original block before explosion
vL = velocity of piece L after explosion
vR = velocity of piece R after explosion
From the conservation of linear momentum, we know that the initial momentum of the block must equal the sum of the momenta of the two pieces after the explosion. This can be expressed as:
mv = m(vL + vR)
Next, we can use the work-energy theorem to relate the change in kinetic energy to the work done by friction. In this case, the work done by friction is equal to the force of friction multiplied by the distance traveled. This can be expressed as:
ΔK = W = Fd
Now, we can use the given information to set up two equations:
For piece L:
ΔKL = FdL = (µLmg)(dL) = 0.4mg(dL) = 0.4m(vL)^2
For piece R:
ΔKR = FdR = (µRmg)(dR) = 0.5mg(dR) = 0.5m(vR)^2
We can then substitute these equations into our initial equation from the conservation of linear momentum:
mv = m(vL + vR)
And rearrange for the velocity of the original block:
v = vL + vR
Now, we can substitute this into our equations for the change in kinetic energy:
ΔKL = 0.4m(v-vR)^2
ΔKR = 0.5m(v-vL)^2
We can then solve for v by setting these two equations equal to each other and solving for v:
0.4m(v-vR)^2 = 0.5m(v-vL)^2
0.4(v-vR)^2 = 0.5(v-vL)^2
0.4v^2 - 0.8vvR + 0.4vR^2 = 0.5v^2 - 0.5vvL - 0.5vL^2
0.1v^2 - 0.3vvR
18K
  • · Replies 33 ·
