Two infinite charged lines -- find the locations where E=0
The discussion focuses on determining the locations where the electric field (E) is zero between two infinite charged lines, one with a charge density of +1λ and the other with -2λ. The relevant equation for the electric field due to an infinite line charge is E = (1/(2πε₀))(λ/r). The solution involves setting up the equation λ1/r + λ2/(d-r) = 0, substituting λ2 = -2λ1, and solving for the distance r in terms of d. This approach leads to identifying the specific points where the electric field cancels out.
  • Understanding of electric fields generated by line charges
  • Familiarity with the concept of charge density (λ)
  • Knowledge of Coulomb's law and its application to electric fields
  • Basic algebra skills for solving equations
  • Study the derivation of the electric field from an infinite line charge using E = (1/(2πε₀))(λ/r)
  • Explore the relationship between linear charge density (λ) and surface charge density (σ)
  • Learn about superposition principles in electric fields
  • Investigate the effects of varying charge densities on electric field distributions
Physics students, electrical engineers, and anyone studying electrostatics or electric field theory will benefit from this discussion.
Grifter
A very long (infinite), straight line of charge runs parallel to another very long (infinite) straight line of charge. Both lines are uniformly charged, one with +1*(lambda) and the other with -2*(lambda). The distance between them is d. Find (if any) the location(s) where the electric field is zero.
[infinite wire] E = 1/(2(pi)(epsilon naught)) * (lambda)/r
[2 wires] E = (sigma1)(sigma2) / 2(epsilon naught)
sigma=area charge
lambda=line charge
epsilon naught=8.854e-12 C^2/N*m^2
I drew a picture with the positively charged line with E-lines flowing away and the negatively charged line with E-lines flowing in. Between the E-lines flow from positive to negative. Not sure about the relationship between lambda and sigma or how to use an equation to find E=0 with variable charges.
From a distance r from a wire of charge lenght-density λ (Coloumb per meter) the electric field strenght is proportional to λ/r
You want to solve the equation λ1/r + λ2/(d-r) = 0
Just use that λ2 = -2λ1 and solve for r in terms of d
  • · Replies 26 ·
