What is the Magnetic Field Density at the Center of a Solenoid?
The discussion revolves around calculating the magnetic field density at the center of a solenoid, given specific parameters such as length, diameter, number of turns, and current. The subject area is electromagnetism, specifically focusing on solenoids and magnetic fields.
  • The original poster attempts to calculate the total number of turns and apply the formula for the magnetic field in a solenoid. They express confusion regarding the uniformity of the magnetic field at the center and the relevance of the diameter provided in the problem.
Participants are exploring the properties of the magnetic field within an ideal solenoid and discussing the implications of the diameter measurement. Some guidance has been offered regarding the uniformity of the magnetic field, though questions remain about the necessity of the diameter in the context of the problem.
There is a mention of the diameter of the solenoid, which raises questions about its relevance to the magnetic field calculation. The original poster is also navigating the constraints of homework expectations and the need for clarity in understanding the problem setup.
abrowaqas
A solenoid has length L= 1.23m , and inner diameter d=3.55cm. it has five layers of windings of 850 turns each and carries a current i = 5.57 A. what B at its centre?
B= Uo N I /L where Uo is permeability of free space.
i first multiply 5 with 850 to get total number of turns
i-e N= 5*850
then i use the formula for solenoidal field
i-e
B= Uo NI/L
i am little confuse whether at centre it would be same and what about diameter given ?
kindly explain
Remember that the whole point of a solenoid (at least an ideal one) is that the magnetic field is the same at all points in its interior.
diazona please explain your answer.
and kindly tell me that why the value of diameter is given in that problem. will it be used here or its just given to confuse?
I don't see what there is to explain, beyond what I've already said. Can you elaborate on what you don't understand?
That's for you to figure out. The diameter is available to you if you need it, but just because it's given doesn't mean you will need it.
why it is same? that is what i am asking to explain.
thanks for the second part i got it..
You can use Ampere's law to prove that the magnetic field of an ideal infinite solenoid is the same at all points inside it, and zero everywhere outside. That's an exercise worth doing in itself, so you might want to try it.
oh yes i got it.. even i have done it.. but didn;t remember.. thanks.. diazona..
