Calculate Car Speed Across Intersection | Challenging Question
  • Thread starter Thread starter thomasrules
The problem involves calculating the speed of a car as it crosses an intersection, given its acceleration and the time taken to traverse the intersection. The context is rooted in kinematics, specifically focusing on uniform acceleration and motion equations.
  • The original poster expresses uncertainty about the initial speed of the car and how to determine the time at the halfway point. Some participants suggest using kinematic equations to find the initial velocity and the time at which the car has traveled 20 meters.
Participants are exploring different approaches to the problem, with some providing guidance on using kinematic equations. There is an ongoing dialogue about the specific equations to use and how to apply them, but no consensus has been reached yet.
The original poster is facing challenges due to a lack of clarity on initial conditions and the application of kinematic equations. There is an emphasis on understanding the setup of the problem rather than arriving at a solution.
thomasrules
A car is observed to cross an intersection in 4s. If the intersection is 40 meters wide, and the car accelerated at 3.3m/s^2, calculate its speed when half-way across the intersection.
I have been having a tought time with this problem because I'm not sure what the initial speed is. Also I don't know what the time would be at half. Its confusing, please help
1. You know the time when it has traveled 40meters, and the constant acceleration during that period.
Use this info to determine the initial velocity, from the equation giving you the distance traveled as a function of t.
2. Determine the value of "t" when the car has traveled 20 meters (from the same equation for the position).
Insert that value of "t" into your expression for the velocity at time "t".
what is the equation?
someone still help explain more I'm still not getting it
Use arildno reasoning with the kinematic equations for uniform acceleration
[tex]info:[/tex]
[tex]x_{o} = 0 m[/tex]
[tex]x = 40 m[/tex]
[tex]a = 3.3 m/s^2[/tex]
[tex]t = 4s[/tex]
Using this equation you can get the initial speed
[tex]x - x_{o} = v_{o}t + \frac{1}{2}at^2[/tex]
Now using the same equation, you can get the time t, with a displacement of 20 m and same acceleration
Now using this equation, you can plug in the time t, and find the speed at that time (at 20 m)
[tex]v = v_{o} + at[/tex]
arildno answer couldn't be any more clear.
  • · Replies 17 ·
