Question about dissolving Ammonium Chloride in Water
  • Thread starter Thread starter vwishndaetr
    Water
The discussion revolves around the temperature change observed when dissolving ammonium chloride in water, specifically comparing the effects of using different volumes of water and amounts of ammonium chloride in a lab experiment. The focus is on understanding the relationship between the quantities of solute and solvent and the resulting temperature change, which is tied to the endothermic nature of the dissolution process.
  • Exploratory, Technical explanation, Conceptual clarification, Mathematical reasoning
  • One participant questions how the temperature change would be affected if both the amount of ammonium chloride and the volume of water were doubled.
  • Another participant suggests that doubling the mass of ammonium chloride would require double the heat for dissolution, prompting a calculation involving the heat equation Q = m c Δt.
  • A subsequent reply raises the concern of whether doubling both the heat and the water would result in the same temperature change, indicating uncertainty about the relationship between these variables.
  • Further clarification is provided that the temperature change is a function of the ratio of solute to solvent, implying that if both quantities are doubled, the temperature change remains unchanged.
  • One participant concludes that the calculations suggest the temperature change would remain the same, reinforcing the idea that the ratio is key.
Participants generally agree that if both the amount of ammonium chloride and the volume of water are doubled, the temperature change remains the same. However, there is some initial uncertainty and exploration of the underlying principles before reaching this understanding.
Participants discuss the implications of the heat equation and the concept of ratios in the context of temperature change, but there are no explicit mathematical resolutions or detailed calculations provided in the discussion.
This discussion may be useful for students or individuals interested in thermodynamics, particularly in understanding the principles of heat transfer during dissolution processes in chemistry.
vwishndaetr
This is a question from a lab previously done for my chem class.
If you had used 40 mL of water and 6 g of ammonium chloride, rather than the 20 mL and 3g in the experiment, would you expect to get a larger, smaller, or identical temperature change?
In the experiment I dissolved 3g in 20 mL and the temperature dropped 10.7*. Now, I understand there is an endothermic reaction and it is caused by the lattice energy from the breaking of ionic bonds, but I'm not sure how it is affected when BOTH are doubled. Being both water and ammonium chloride.
Seems to me though more water would result in a smaller temp drop, and more ammonium chloride would result in a larger temp drop, so being that both are involved, the temp change would remain the same?
Though that's what my intuition tells me, I am not convinced since I really have no "details" to back up what I think.
Any input??
Thanks.
Your intuition is right, although you may need more systematic approach.
If you use twice the mass of NH4Cl, how many times more heat do you need for dissolution?
Do you know how to calculate amount of heat involved for a given mass and temperature change of water?
If you're referring to
[itex]Q = m\ c\ \Delta t[/itex]
Then maybe? If this is the equation, then yes, double the mass would result in double the heat. But does double the heat really result in a same temp change for double the water?
I mean, if both water and heat are doubled, delta t would in fact stay equivalent to the first change no?
Feels like I'm walking in circles.
You are on the right track - if you feel like you are walking in circles, that's because in fact you do, but that's the correct route!
You doubled the mass of the salt - so you have twice the heat. That makes it 2Q.
You doubled the mass of the water and salt - that makes mass of solution 2m.
So you have
and
[itex]2Q = 2m\ c\ \Delta t[/itex]
for the first and second case. Calculate Δt for each.
Note: m is now mass of the solution (and earlier I asked about mass of water) - but it doesn't change the outcome not the logic behind these calculations.
So the 2's pretty much cancel and I am left with the same temp change.
Exactly - temperature change is a function of RATIO, if both quantities change but ratio is constant, temperature change doesn't change.
Nice. Thanks for that. Even though I submitted with a different response, at least I know what the real deal is.
19K
12K
