Watching Light Travel in a Coil: Is It Possible?
  • Context: High School
  • Thread starter Thread starter dusty8683
    Coil Light Travel
The discussion confirms that the phenomenon described by the user is indeed possible through the use of fiber optics. Fiber optics consist of strands of glass optical fibers that transmit data signals via total internal reflection. This process occurs when light transitions from a medium with a higher index of refraction to one with a lower index, allowing the light to bounce off the internal walls of the glass tube. Snell's law is essential for determining the critical angle necessary for total internal reflection to occur.
  • Understanding of fiber optics technology
  • Knowledge of total internal reflection principles
  • Familiarity with Snell's law and its application
  • Basic concepts of light behavior, including reflection and refraction
  • Research the principles of fiber optics and their applications in telecommunications
  • Study Snell's law in detail, focusing on critical angles and refraction indices
  • Explore the construction and design of optical fibers
  • Investigate practical demonstrations of total internal reflection using various materials
This discussion is beneficial for physics students, optical engineers, telecommunications professionals, and anyone interested in the practical applications of light behavior in fiber optics.
dusty8683
my uncle was describing something that showed light traveling at a slow speed and i had no idea how it worked. he said it was a clear solid plastic like tube wrapped around in a coil and when you shined a light in one end you could watch it enter the coil, spin around the coil, and then exit the other end. is that even possible? if so what was it and how did it work?
Science news on Phys.org
Yes, it is possible. Your uncle basically described the use and operation of fiber optics. Fiber optics are (basically) strands of glass optical fibers that are used to carry data signals (such as voice, video) in telecomm. networks. They also typically have a diameter of 60 μm
Light can do some really interesting things, especially since it is able to bend around objects, reflect and refract off of (or because of) objects. So with these thoughts in mind, the idea that your uncle described can be done with light because of total internal reflection. Total internal reflection occurs when light attempts to move from a medium of with an higher index of refraction (n1) to a medium of lower index of refraction (n2). So, in order for the light to move through the glass tube, the light must undergo multiple internal reflection incidences. Basically, the light is bouncing off the internal walls of the glass as it is reflected - even around a curve. And to determine the likelihood of total internal reflection you will need to use Snell's law which is: sin θc = n2/n1 ; where θc is the critical angle (which is what you are looking for).
You wouldn't actually see it going through the coil, but would see it coming out the send. Even if you could see it in the coil, you still wouldn't be able to see the movement as you would with a clear hose with water and colored debris flowing through.
  • · Replies 19 ·
  • · Replies 24 ·
  • · Replies 93 ·
