Where is the Classically Forbidden Region for a Ground-State Hydrogen Atom?
  • Thread starter Thread starter Shafikae
    Hydrogen
The discussion revolves around identifying the classically forbidden region for a ground-state hydrogen atom and calculating the probability of finding the electron within that region. The subject area includes quantum mechanics and atomic physics.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss the definition of the classically forbidden region and its relation to kinetic energy. There are attempts to clarify the relationship between parts (a) and (b) of the problem, with some participants questioning the calculations and interpretations of the probability results.
There is an ongoing exploration of the problem, with some participants providing guidance on the relationship between the forbidden region and the probability calculations. Multiple interpretations of the problem's requirements are being discussed, particularly regarding the mathematical approach to finding the forbidden region.
Participants note confusion regarding the problem's phrasing and the implications of the calculations. There is mention of specific parameters such as the Bohr radius and the limits of integration for probability calculations, indicating a focus on the mathematical aspects of the problem.
Shafikae
Any region of space in which the kinetic energy T of a particle would become negative is forbidden for classical motion. For a hydrogen atom in the ground state:
(a) find the classically forbidden region
(b) using the ground-state wave function [tex]\psi[/tex]100(r), calculate the probability of finding the electron in this region.
I was able to do part (b) and I got 0.238103.
As for part (a), I don't know what to do. I'm able to do the mathematics, I just can't seem to start a problem. Thank you.
Ehhmmm, but if you have calculated the probability of finding the electron in the classically forbidden region, you already must know what this region is, right?
(and yes, you could have added that to your other post. helps keeping an overview)
I think your answer to part (b) is wrong as well.
Oh you grey earl... totally forgot 1-P ...
Vela so part (b) is incorrect? This is how I got the answer...
Since a0 = bohr radius
then the prob of the electron being found in classically forbidden region is (r>2a0)
Then I took the integral of r2 exp(-2r/a0) (4/a0) from 2a0 to infinity... is that not right?
That's the right method (though I think you meant you had a03 in the denominator). I must have screwed up somewhere in my calculation yesterday. Today, I redid it and got the same answer you did. Sorry to mislead you.
ya sorry i meant cubed. ok good good so I'm on the right track. Thanks so much.
for part (a), i know i would subtract part (b) from 1... but i want to do that actual math.
Does the integral remain the same and just change the limit of integration from 0 to a0 ?
I think you're misunderstanding what the problem is asking for. It's just asking where in space would the electron never be found classically. You've already figured that out (and used it to calculate the answer to part (b)). You wouldn't find it anywhere farther away than 2a0 from the nucleus; in other words, the classically forbidden region is r>2a0.
ohhhhhhhhhhhhhhhhhhhhh! I don't know why i thought number 1 was asking for something totally different! thanks a bunch!
I thought part (a) was asking for the prob of not finding it in the forbidden region.
  • · Replies 21 ·
  • · Replies 0 ·
