Making a metal permanently positive and permanently negative
This discussion focuses on the methods to create and manipulate static electric charges on metal sheets. The user inquires about making a metal sheet permanently positive or negative and the behavior of charged plates. A practical solution is provided using a simple electroscope made from aluminum strips and a plastic ballpoint pen as a rubbing agent. The conversation emphasizes that even with basic equipment, significant electrostatic experiments can be conducted effectively.
  • Understanding of static electricity principles
  • Familiarity with basic electrostatic devices, specifically electroscopes
  • Knowledge of materials that can generate static charge, such as plastic and fur
  • Basic experimental skills for conducting hands-on science experiments
  • Research the principles of electrostatics and charge transfer
  • Learn how to construct and use an electroscope for static electricity experiments
  • Explore various rubbing agents and their effectiveness in generating static charge
  • Investigate the behavior of charged objects, including attraction and repulsion
This discussion is beneficial for students, educators, and hobbyists interested in practical electrostatics experiments, as well as anyone looking to understand the fundamental concepts of electric charge and static electricity.
Hypothesis
Hi
I am in a spot of bother. Actually I live in an under developed country where science and technology is not upto the modern standards and there is very little practical facilities. I want to ask if I have a metal sheet of some thickness how it could be made permenantly positive and permenantly negative and is it possible that a plate is positively charge for one second and it is negatively charged in the other by any means. And lastly if one plate is positive and other is negative will they actually move toward each other and positive-positive will move away from each other.
THANKS!
Hypothesis,
if you're interested in electrostatic experiments, I think it's not a big drawback if you have only simple equipment at hand. On the contrary, since most of the effects have been discovered in ancient times, it should be possible reproducing them with simple equipment today.
First, you need a simple device which reliably indicates electric charge. Two thin strips of aluminum (e.g. from a chocolate wrapper) will do. Hang them down from a piece of uninsulated wire, and stick the wire thru a small bottle's cork from its bottom. Then replace the cork into the bottle, so that the strips hang freely inside. You might want to attach a small metal ball (crumpled aluminum) to the top end of the wire sticking out of the cork. Now you have an electroscope.
Next, try rubbing agents. A plastic ballpen might do. Rub it fast, but not hard, against some fur (I use my own hair), and then try to transfer the electricity to your electoscope. If there is any charge, the aluminum strips will spread apart and stay like this. You can discharge them by touching the conductor ball with your finger.
Play around with different rubbing agents, modify your electroscope, and so on. I'm sure you will discover all major effects in static electricity, and... it's fun!
12K
  • · Replies 26 ·
