Need help solving a thermodynamics problem
  • Thread starter Thread starter sonna
    Thermodynamics
The discussion revolves around solving a thermodynamics problem involving a rigid tank and a piston-cylinder assembly. Initially, the tank contains 3 kg of air at 500 kPa and 290 K, while the piston-cylinder assembly holds 0.05 m³ of air at 200 kPa and the same temperature. As air leaks from the tank, the pressure drops to 200 kPa, maintaining a constant temperature. The total energy transfer by work is calculated using the formula ΔU total = nRT ln(P2/P1) + nRT ln(V2/V1), resulting in -75.43 kJ for the energy transfer by heat.
  • Understanding of ideal gas behavior
  • Familiarity with the first law of thermodynamics
  • Knowledge of the ideal gas law (PV = mRT)
  • Ability to perform logarithmic calculations
  • Study the first law of thermodynamics in detail
  • Learn about energy transfer calculations in thermodynamic systems
  • Explore the application of the ideal gas law in various scenarios
  • Investigate the effects of constant temperature processes on gas behavior
Students and professionals in mechanical engineering, thermodynamics enthusiasts, and anyone looking to deepen their understanding of energy transfer in gas systems.
sonna
A rigid tank initially contains 3kg of air at 500KPa, 290K. The tank is contained by a valve to a pistion-cylinder assembly oriented vertically and containing 0.05m^3 of air initially at 200KPa,290K. Although the valve is closed, a slow leak allows air to flow into the cylinder until the tank pressure falls to 200KPa. The weight of the piston and the pressure of the atmosphere maintain a constant pressure of 200Kpa in the cylinder; and owing to heat transfer, the temperature stays constant at 290K. For the air, determine the total amount of energy transfer by work and by heat, each in kj. Assume ideal gas behaviour. :
I have trouble solving this problem. Please anyone can u help me to get an edge on solving this problem?
Answer:The total amount of energy transfer by work is equal to the change in internal energy of the air in the tank plus the change in internal energy of the air in the piston-cylinder assembly. Assuming ideal gas behavior, the change in internal energy of the air in the tank is given byΔU tank = nRT ln(P2/P1)where n is the number of moles of air in the tank, R is the gas constant, T is the temperature of the air, and P1 and P2 are the initial and final pressures, respectively. The change in internal energy of the air in the piston-cylinder assembly is given byΔU piston-cylinder = nRT ln(V2/V1)where V1 and V2 are the initial and final volumes, respectively.Therefore, the total amount of energy transfer by work is given byΔU total = nRT ln(P2/P1) + nRT ln(V2/V1)For the air in the tank, n = 3 kg/28.97 g/mol = 0.10347 mol, R = 8.314 J/mol·K, T = 290 K, P1 = 500 kPa, and P2 = 200 kPa.For the air in the piston-cylinder assembly, n = 0.05 m3/22.4 L/mol = 0.002235 mol, R = 8.314 J/mol·K, T = 290 K, V1 = 0.05 m3, and V2 = 0.05 m3.Substituting these values into the equation above, we getΔU total = (0.10347 mol)(8.314 J/mol·K)(290 K)ln(200/500) + (0.002235 mol)(8.314 J/mol·K)(290 K)ln(0.05/0.05)ΔU total = -75.43 kJThe total amount of energy transfer by heat is equal to the sum of the change in internal energy of the air in the tank, the change in internal energy of the air in the piston-cylinder assembly, and the heat transfer from the surroundings to the
Hello! I can definitely help you with this thermodynamics problem. First, let's break down the information given and identify the key variables that we need to solve for.
1. Initial conditions:
- Rigid tank with 3kg of air at 500KPa, 290K
- Piston-cylinder assembly with 0.05m^3 of air at 200KPa, 290K
2. Process:
- Valve is closed, but there is a slow leak allowing air to flow into the cylinder
- Tank pressure decreases to 200KPa
- Piston weight and atmospheric pressure maintain a constant pressure of 200KPa in the cylinder
- Heat transfer occurs and temperature remains constant at 290K
3. Objective:
- Determine the total amount of energy transfer by work and heat for the air in the cylinder, in kJ.
Now, we can use the ideal gas law to solve for the missing variables. The ideal gas law is given by:
PV = mRT
Where:
P = pressure (Pa)
V = volume (m^3)
m = mass (kg)
R = gas constant (8.314 J/mol*K)
T = temperature (K)
We know that the temperature and volume remain constant, so we can rearrange the equation to solve for the final pressure in the cylinder:
P = (mRT)/V
Plugging in the values, we get:
P = (3kg * 8.314 J/mol*K * 290K) / 0.05m^3
P = 144,924 Pa
Since the pressure in the cylinder remains constant at 200KPa, we can set up an equation to solve for the mass of air that flows into the cylinder:
P1V1 = P2V2
(500KPa)(0.05m^3) = (200KPa)(V2)
V2 = 0.125m^3
Now, we can use the ideal gas law again to solve for the mass of air that flows into the cylinder:
m = (PV)/RT
m = (200KPa * 0.125m^3) / (8.314 J/mol*K * 290K)
m = 0.0096 kg
Next, we can use the formula for work done by a gas:
W = PΔV
Where:
W = work (J)
P =
