How Do You Find the Density Function of a Sum of Exponential Random Variables?
The discussion revolves around finding the density function of the sum of independent, identically distributed exponential random variables. Participants explore various methods, including induction and convolution, to derive the density function, which is related to the gamma distribution.
  • One participant states that the sum of independent exponential random variables follows a gamma distribution and suggests using induction to find the density function.
  • Another participant proposes using characteristic functions to show that the convolution of exponential distributions results in a gamma distribution, but expresses uncertainty about which method is more effective.
  • A participant attempts to compute the density of the sum of two exponential random variables using convolution but encounters difficulties with the integration limits and evaluates the integral incorrectly.
  • Another participant points out the error in the integration limits, clarifying that they should not extend from negative infinity to infinity due to the nature of the exponential distribution.
  • One participant suggests that understanding the characteristic functions of the exponential and gamma distributions could simplify the problem, indicating that the characteristic function of the sum can be expressed in terms of the characteristic function of the individual distributions.
Participants generally agree on the relationship between the sum of exponential random variables and the gamma distribution, but there is no consensus on the best method to derive the density function. Multiple approaches are discussed, and some participants express uncertainty about their calculations.
Limitations include potential misunderstandings regarding the integration limits in convolution and the assumptions made in applying induction. The discussion does not resolve the mathematical steps necessary to derive the density function.
glacier302
Let X1,...,Xn be independent, identically distributed random variables with exponential distribution of parameter λ. Find the density function of S = X1+...+Xn. (This distribution is called the gamma distribution of parameters n and λ). Hint: Proceed by induction.
At first I tried computing the characteristic function of X1+...+Xn, which is equal to the characteristic function of X1 raised to the nth power since the Xi are independent and identically distributed. But this didn't look like the characteristic function of any probability distribution that I know, so that was a dead end.
We're told to proceed by induction, but I'm not sure how to do that with density functions.
Useful information:
The probability density function of each of the Xi is f(x) = λe^(-λx).
The probability density function of the sum of two independent random variables is the convolution of their density functions. So if the density function of X is f(x) and the density function of Y is g(x), then the density function of X+Y is ∫f(T)g(x-T)dT (integral from -∞ to ∞).
Any help would be much appreciated! : )
To use induction in evaluating the product of n+1 characteristic functions, you get to assume that the product of the first n of them gives you the characteristic function of a gamma distribution. So the problem will be to show that the characteristic function of a gamma distribution times the characteristic of an exponential gives you the characteristic function of another gamma distribution.
To use induction in evaluating the convolution of n+1 exponentials, you have a big multiple intergral in n+1 variables ds1, ds2,... etc. Induction let's you say that evaluating the integral with respect to the first n of these variables results in a gamma distribution. So you need to show that the convolution of a gamma distribution with an exponential produces another gamma distribution.
I haven't done the problem, so I don't know which of those methods works. If the integration doesn't seem to work, try applying integration by parts. That's just speculation on my part, because, as I said, I haven't worked the problem.
Okay, so now I'm trying to do induction. Since the Xi are exponentially distributed, X1 has Gamma distribution with parameters 1 and λ. But when I try to find the density of X1 + X2 where X1 and X2 are exponentially distributed, I get this:
density of (X1+X2) = ∫f(x-y)f(y)dy from y = 0 to y = ∞ (since X1, X2 are independent)
= ∫λe^-(λ(x-y))λe^(-λy)dy
= λ^2∫e^(-λx)e^(λy)e^(-λy)dy
= λ^2∫e^(-λx)dy
= λ^2e^(-λx)∫dy
= λ^2e^(-λx)*y (evaluated from y = 0 to y = ∞)
When I calculated the density of a random variable with Gamma distribution and parameters 2 and λ, I got λ^2e^(-λx)*x. This looks kind of like the second to last step of my work above, except that there's an x instead of y, and it isn't evaulated from 0 to ∞.
Am I making some stupid mistake here with evaluating the integral??
The limits of integration aren't from minus infinity to infinity since the quantity (x-y) can't be negative for the exponential distribution. The variable y only goes from 0 to x.
You are making it far too hard. I assume you know the forms of the characteristic functions of exponential and gamma functions. Let
[tex] \phi_x(t)[/tex]
stand for the characteristic function of an exponential distribution (this is the c.f. of [itex]X_1[/itex]). The c.f. of [tex]X_1 + X_2[/tex] is
[tex] \int \int exp(t(x_1 + x_2)) f(x_1) f(x_2) \, dx_1 dx_2 = \left(\phi_x(t)\right)^2[/tex]
With a little observation you should be able to show that this is the c.f. function of a particular gamma distribution. You've just shown the statement is true for n = 2.
Now make the induction assumption: that for some [tex]k \ge 2[/tex],
[tex] T = X_1 + X_2 + \cdots + X_k [/tex]
has a gamma distribution. Then you know what the c.f. for this sum is. Now, for [tex]k + 1[/tex] you have
[tex] \iiiint exp[t(x_1 + x_2 + \cdots + x_k + x_{k+1})] f(x_1) f(x_2) \cdots f(x_k) f(x_{k+1}) \, dx_1 dx_2 \cdots dx_k dx_{k+1}[/tex]
Break this into two expressions: one with the sum over x1 through xk, the other over x{k+1}. Each integration gives a c.f., and you know the form of each one.
