New Reply
Thermodynamics, first law, pressure increase, volume increase
Share Thread Thread Tools
Mar22-11, 06:52 PM   #1
How much heat energy is needed to heat oxygen, mass=10g which is on temperature t=27°C to make the volume go up by 3 times while pressure is constant, and after that increase the pressure 2 times while volume is constant. Specific heat capacity of oxygen is cp= 908 J/KgK and cv=653 J/kgK.
2. Relevant equations
Q=m*cv(p)*delta(T)
Q=U+pV
3. The attempt at a solution
I tried and tried and triiied and i hate to come here to look for an answer its a probably an easy one, but i have a mental blockade, can't think of anything.
I have final result Q=11,32kJ if it helps(solution to this from my book)
I simply cannot find any relation or equation so that i can relate pressure and volume etc. I know general fomula Q=U+pV, but that didn't get me anywhere..
Thanks
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Ants and carnivorous plants conspire for mutualistic feeding
>> Forecast for Titan: Wild weather could be ahead
>> Researchers stitch defects into the world's thinnest semiconductor
Mar22-11, 08:20 PM   #2
pV/T = const
const pressure:
1/(27+273) = 3 / (T + 273) --> dT = 600
Q1 = mc_v dT = 0.01kg * 908 * 600 = 5448 KJ
const vol:
1 / (627 + 273) = 2 / (T + 273) --> dT = 900
Q2 = mc_pdT = 0.01kg * 653 * 900 = 5877 kJ
Q_total = Q1 + Q2 = 11325kJ
Mar22-11, 08:28 PM   #3
Quote by ppzmis View Post
pV/T = const
const pressure:
const vol:
See, I had absolutely no idea about pV/T part, that changes everything. THANK YOU VERY MUCH!!!!!!!!!!!!!!!!!!!!!!!!
I just had like 5 in a row "aha" moments :D Gas equation, fixed quantity of gas etc
Mar22-11, 11:16 PM   #4
Recognitions:
Homework Helper Homework Help
pV/T = const
const pressure:
const vol:
I think you meant to write C_p in the first calculation (Q1) and C_v in the second (Q2). You have used the correct values though.
AM
New Reply
Thread Tools
Similar Threads for: Thermodynamics, first law, pressure increase, volume increase
Thread Forum Replies
increase in speed, increase in energy Introductory Physics Homework 1
Increase gas pressure in unchanged volume Introductory Physics Homework 3
Thermodynamics: Amount of work required to increase pressure at constant volume Introductory Physics Homework 6
Will an increase of voltage also increase Amps? Introductory Physics Homework 1
Einstein's:Mass increase resulting from Acceleration increase Special & General Relativity 30
