Specific relativity Length Contraction and Time dialation question
The discussion revolves around a problem in special relativity, specifically focusing on length contraction and time dilation. The scenario involves a spaceship traveling towards Earth at a significant fraction of the speed of light, firing projectiles, and the measurements of distances and masses from different reference frames.
  • Participants explore the correct velocity to use for calculations, questioning whether the speed measured from Planet X or Earth is appropriate. There is also discussion about the concept of negative velocity in the context of approaching objects.
  • Some participants attempt to derive the proper length from the contracted length and question the validity of their calculations, indicating a potential misunderstanding of the relationship between proper and contracted lengths.
  • Questions arise regarding the definition of relativistic mass and the distinction between rest mass and observed mass from different frames of reference.
The discussion is ongoing, with participants providing insights and clarifications on the concepts of proper length and relativistic mass. There is recognition of the need to differentiate between measurements in different frames, and some participants express confusion about circular reasoning in their calculations. Guidance has been offered regarding the proper distance and the nature of mass as measured by the pilot.
Participants note the complexity of the problem due to the relativistic speeds involved and the need to carefully consider the reference frames for measurements. There is an acknowledgment of the constraints imposed by the problem's setup, including the need for clarity on definitions and assumptions related to velocity and mass.
Galgenstrick
Special relativity Length Contraction and Time dilation question
Planet X is 18 Light Years from earth, A spaceship moving towards the Earth at a speed of 0.82C (Measured from Planet X) fires a series of 1.2 cm long and 2.1 gram mass (as measured by the pilot) projectiles with a speed of 0.72C (Measured by the pilot) towards the earth. At the moment the projectiles were fired the pilot measured his distance from the Earth to be 1.3 light years.
a.) From the point of view of the observer on earth, how far away is the spaceship from Earth when it starts firing?
There are parts b-f, That I will add later if I get stuck on these as well.
L'=L / [tex]\gamma[/tex]
I am having two difficulties. First, the speed of the spaceship is 0.82C as measured by Planet X, is this the velocity I need to answer the question? or do I need to find the velocity as it would be measured by the earth?
Second, Is there "negative velocity" in this equation? What I mean is, since the spaceship is traveling towards the earth, would the velocity be negative? Or is velocity always positive whether or not an object is moving towards or away from you?
Presumably, Planet X and the Earth are at rest with respect to each other. So they both measure the same speed for the spaceship.
Does it matter? In the equation you need for this question, v enters into the expression for gamma as v^2.
You just saved the day, thank you so much!
There is one other detail I missed. I was using 1.3 Light Years as the proper length, But I don't think this is correct. how can I calculate the proper length?
If the 1.3 LY distance is the measured contracted length (in the ship's frame), what must be the proper length (in the Earth's frame)?
I came up with this, 1.3/sqrt(1-v^2/c^2)... Since 1.3=L/gama, does that look correct?Edit: this doesn't seem to work, because it will give me 1.3 LY observed by the earth, which doesn't make sense.
Looks OK.
:confused: L = 1.3*gamma.
Doc Al said:
Looks OK.:confused: L = 1.3*gamma.
My textbook gives me L'=L/gamma, or L=L(proper) / gamma
1.3/sqrt(1-v^2/c^2) is the same as 1.3*gamma
Here is what I have so far, and why I think it is not correct:
Step 1:
Find the proper distance between ship and earth,
L=L(proper) / gamma, so 1.3 = L(proper) * sqrt(1-(0.82c)^2/c^2)
Solving for L(proper) = 2.2713 LY.
Step 2:
Find the contracted distance as observed by the earth.
L=L(proper) / gamma
L= 2.2713 * sqrt(1-(0.82c)^2/c^2)
L= 1.3 LY
So you see I just went in a circle. I found the proper length, then used the proper length and got the contracted length as observed by the pilot as my answer. Somewhere I am missing something.
Step 1:
In this context the proper distance is that measured in the Earth frame. You're done.
Step 2:
L=L(proper) / gamma
L= 1.3 LY
Yes, you went in a circle. Imagine that there's a ruler stretching from Earth to planet X. That ruler measures 'proper' distance between those two, which is the distance according to Earth observers. At some point along that ruler, the spaceship starts firing projectiles. According to the spaceship, the distance is 1.3 LY from earth. The spaceship, which is moving, sees the contracted distance. To find the proper distance, just multiply by gamma.
AHH! I see now. Thank you again!
Looks like I have one more question for the last part (part f) of this problem.
f.) Given that one of the projectiles misses the Earth. What is the mass of the projectile as observed from earth.
I am probably going to need the equation E=gamma*m*c^2. I know the mass of the projectile as measured from the pilot, however; I don't know the rest mass of the projectile to use this equation. I am not exactly sure where to start. I also know the speed of the projectile as observed (that was part b).
I presume that they want the relativistic mass of the projectile.
What's the definition of relativistic mass?
The mass given is the rest mass of the projectile.
Good--you'll need that speed.
I couldn't find anything in my textbook about relativistic mass, but here is what I found online: m = gamma * m0,
Also, Why is the mass observed by the pilot the rest mass if it is moving 0.82c?
That's what you need.
When they give the mass of the projectile as 2.1 grams as measured by the pilot, presumably they mean before he fires them. So that's the rest mass of the projectiles.
Right, but since the pilot is moving at 0.82c relative to the earth, so is the projectile before it is fired. So wouldn't I need the mass of the projectile as it would be if it were motionless on Earth?
The rest mass of the projectile will be the same in any frame in which it is at rest. When the pilot measured the mass of the projectiles, presumably they were at rest with respect to him. So 2.1 g is their rest mass.
To find their relativistic mass, you need to know how fast they are moving with respect to the observer.
  • · Replies 29 ·
  • · Replies 63 ·
  • · Replies 54 ·
  • · Replies 24 ·
