Find Maximum Velocity Range in Velocity Selector using Vmax and B values
  • Thread starter Thread starter michael650
    Velocity
The discussion focuses on calculating the maximum velocity range of a proton in a velocity selector using the equations Vmax = (eB²Ld) / (mp) and vx = V / (Bd). The parameters include a maximum voltage of 7.65x105 V, a magnetic field strength B ranging from 0 to 2 Teslas, and a distance d between parallel plate capacitors varying from 1mm to 10mm. The analysis reveals that while theoretically, velocities can approach infinity with extremely low values of B, practical calculations yield finite ranges based on the selected parameters.
  • Understanding of electromagnetic theory, specifically the behavior of charged particles in electric and magnetic fields.
  • Familiarity with the equations of motion for charged particles, particularly in velocity selectors.
  • Knowledge of fundamental constants such as the elementary charge (e) and the mass of a proton (mp).
  • Basic proficiency in algebra for manipulating equations and understanding variable relationships.
  • Explore the effects of varying magnetic field strengths on particle velocities in velocity selectors.
  • Investigate the implications of using different distances (d) between parallel plate capacitors on velocity outcomes.
  • Learn about the practical applications of velocity selectors in particle physics experiments.
  • Study the limitations and assumptions in theoretical calculations of particle velocities in electromagnetic fields.
Physicists, electrical engineers, and students studying electromagnetism or particle acceleration who seek to understand the dynamics of charged particles in velocity selectors.
michael650
I have a velocity selector that consists of two parallel plate capacitors each with a diameter of 20cm (L), and a distance between them d. The capacitors are connected to a power source that delivers a voltage V. A magnetic field goes into the selector and has a strength B. Given that d can be from 1mm to 10mm, B can be from 0 to 2Teslas, and there is a maximum voltage that the battery can put out (0V to Vmax). With these parameters, I need to find the range of velocities that I can get out of a proton put into the velocity selector.
Vmax = ( eB2Ld ) / ( mp )
vx = V/Bd
I have been working on this problem for a good few days now, and I've put in a tremendous amount of effort. It took me a long time to calculate the maximum voltage (which is 7.65x105 V. With all the given parameters, and the second equation, I figured I would be able to find the range of velocities easily, but I was wrong. I noticed that I can get a velocity anywhere from 0 mps to an infinitely large one when insertting an incredibly small value for B (1x10-30 Teslas). The numbers of this problem do not need to be realistic, they just have to work out mathematically
. Therefore, I was wondering if there is any way to find the range of velocities without getting an infinitely large one? The range of velocities you can get out of a proton put into the velocity selector depends on the maximum voltage that the battery can put out and the strength of the magnetic field going into the selector. The maximum voltage (Vmax) is determined by the following equation: Vmax = (eB2Ld)/(mp), where e is the elementary charge, B is the magnetic field strength, L is the diameter of the parallel plate capacitors, d is the distance between them, and mp is the mass of the proton. Using this equation, you can calculate the range of velocities you can get out of the velocity selector by substituting in different values for the magnetic field strength B and maximum voltage Vmax. For example, if you set the magnetic field strength at 0 Teslas and the maximum voltage to 7.65x105 V, then the range of velocities you can get out of the velocity selector will be from 0 mps to 7.65x105 mps. If you increase the magnetic field strength to 1 Tesla and keep the maximum voltage the same, then the range of velocities you can get out of the velocity selector will be from 0 mps to 7.65x104 mps. In summary, the range of velocities you can get out of a proton put into the velocity selector depends on the maximum voltage that the battery can put out and the strength of the magnetic field going into the selector. By changing these two parameters, you can calculate the range of velocities you can get out of the velocity selector.
  • · Replies 21 ·
  • · Replies 26 ·
