Projectiles launched from an angle
  • Thread starter Thread starter alanna
    Angle Projectiles
The discussion revolves around projectile motion, specifically focusing on problems involving projectiles launched at an angle. Participants are exploring how to determine the launch angle and initial velocity given certain parameters such as vertical and horizontal displacements.
  • Participants are attempting to understand the relationship between vertical displacement, initial velocity, and launch angle. Questions are raised about using vertical displacement and initial velocity to find the launch angle, as well as how to calculate initial velocity given total displacements and launch angle. There is also discussion about the components of projectile motion and the nature of horizontal velocity.
The discussion is ongoing, with participants sharing their thoughts and methods. Some guidance has been offered regarding the use of equations of motion and trigonometric relationships, but there is no explicit consensus on the best approach. Participants are still seeking clarification on specific terms and concepts.
There are indications of confusion regarding terminology, such as the meaning of "v_h," and participants are working through assumptions related to the components of projectile motion. The original poster has expressed difficulty with the problem, suggesting a need for further exploration of the concepts involved.
alanna
I know how to solve projectile problems when they are launched from an angle if I know the angle and the initial velocity, I need to know:
a. Can you use the vertical displacement (m) and the initial velocity(m/s) to find the angle?
b. How do you find the initial velocity when you know the total horizontal displacement and the total Vertical displacement and the angle at which it is launched? (i.e. a ball is launched at a 35.0 degree angle and it clears a 21.0m wall 130.0m away, what is the initial velocity at which the ball was thrown?)
Answer A
1. Yes you can.
2.Try this way
v_end^2=v_h^2+2a(x-x_0)
0=v_h^2+2g(0-h)
(2g(0-h))^1/2=v_h
sinX=V_h/initial velocity
But I don't know the Final velocity or the initial velocity of the horizontal.
The Horizontal has constant speed. Vx is constant.
The Velocity of the projectile motion can be done with its components, where component x is an uniform speed movement, and component y will experience constant acceleration movement.
For b, the attached picture should be a correct method of finding the initial velocity, using the appropriate formulae of motion. (v^2 - u^2 = 2as and basic trigonometric..)
Thank you so much, I've been stuck on a problem like this forever.
sorry but what do u mean when u use v_h?
vertical velocity? vertial height (S_y)?
Sin x = ? U_y / U_x ?
  • · Replies 39 ·
  • · Replies 36 ·
  • · Replies 38 ·
