Angular Acceleration of a Rotating Wheel: Solving a Common Question
  • Thread starter Thread starter mickeychief
    Rotating Wheel
The discussion revolves around a problem involving angular acceleration of a rotating wheel, specifically focusing on a scenario where the wheel has an initial angular velocity and a specified angular displacement over a time interval. Participants are exploring the implications of constant angular acceleration in this context.
  • Participants are attempting to identify the correct formula for angular motion and are questioning the interpretation of the problem statement. Some are suggesting writing the angular velocity as a function of time, while others are clarifying the conditions given in the problem.
The discussion is active, with participants providing insights into the problem setup and questioning assumptions. There is a mix of interpretations being explored, particularly regarding the relationship between angular velocity, angular displacement, and angular acceleration. Some guidance has been offered regarding the equations of motion for angular quantities.
Participants note that the problem specifies constant angular acceleration and provides initial conditions, but there is some uncertainty about the formulation of the question and the expected calculations.
mickeychief
Can anyone help me in solving this question?
At t=0, a wheel is rotating about a fixed axis at a constant angular acceleration has an angular velocity of 2 rad/s. Two seconds later it has turned 5 complete revolutions what is the angular acceleration of this wheel??
The question says that the angular acceleration is constant, so why would it have changed two seconds later? Are you sure you were not asked to solve for the angular velocity?
I typed the question just as it was written. I am having trouble finding the formula for the solution, maybe it is written wrong??
I would say that the first step is to write the angular velocity of the wheel as a function of time. Have you tried to do this at all?
The problem didn't say the angular acceleration had changed. It gave the initial angular velocity and the total angle moved in 2 seconds and asked you to calculate the constant angular acceleration.
mickeychief: this is just like straight line acceleration except that you use angles instead of length:
If the accelaration is a, then the velocity after t is at+ v0,where v0 is the initial velocity, and the "distance" moved is (1/2)at2+ v0t. Since you are told that v0= 2 rad/sec and that, with t= 0, the angle ("distance") moved was
"5 complete revolutions"= 5(2pi)= 10pi radians, you have
(1/2)a(4)+ 2(2)= 10pi. Solve for a.
  • · Replies 19 ·
