Solving PSE6 6.P.011: Find Tension in Strings
  • Thread starter Thread starter ramin86
    Tension
The problem involves a 3.85 kg object attached to a vertical rod by two strings, rotating in a horizontal circle at a constant speed of 7.30 m/s. Participants are tasked with finding the tension in both the upper and lower strings.
  • Mixed
  • Participants have attempted various force equations and centripetal acceleration formulas but report difficulties in arriving at correct answers. Some are seeking clarification on their approaches, while others are offering to assist by discussing specific force equations.
The discussion is ongoing, with participants sharing their attempts and equations. Some guidance has been offered regarding the forces involved, but there is no explicit consensus on the correct approach yet.
Participants express frustration and urgency, indicating that they are under pressure to solve the problem correctly. There is mention of a figure that is crucial for understanding the setup, which may not be fully described in the text.
ramin86
Everyone I know is having problems with this question:
3. [PSE6 6.P.011.] A 3.85 kg object is attached to a vertical rod by two strings as in Figure P6.11. The object rotates in a horizontal circle at constant speed 7.30 m/s.
Figure P6.11
(a) Find the tension in the upper string.
N
(b) Find the tension in the lower string.
N
http://www.webassign.net/pse/p6-11.gif for the figure
I've tried using various force equations, only to be wrong. Does anybody know how to do this problem??
Anybody know how to do this problem? Tried a lot of things, but I'm down to my last chance to answer the question correctly
it seems you are desparate, just show me your "force equation and I help you out right know
Well I tried some forms of the centripetal acceleration formula for the upper tension, and I also tried 3.85*9.88(cos of the angle) + 1/2 the horizontal force, but they haven't worked out.
Only because you try to do something, I'm going to help.
Use these forces ==>
T"sin(alpha)-T'sin(alpha)-mg=0 and T"cos(alpha)+T'cos(alpha)=mv^2/r
where T" is the upper tension and T' is the lower tension. Also, if you want to find
cos(alpha) and sin(alpha) use your sketch
  • · Replies 19 ·
15K
