SERS Substrates for Adsorbing Biological Materials
This discussion focuses on the preparation of Surface-Enhanced Raman Spectroscopy (SERS) substrates for adsorbing biological materials, specifically salmonella biofilms. Key methods for creating effective SERS substrates include vapor-deposition, electrochemistry, and glancing angle deposition, with the latter being optimal for achieving a roughened silver layer that enhances SERS signals. Commercially available substrates, such as Klarite, offer reproducibility and reliability compared to in-lab methods. The choice of metal for SERS substrates, such as silver or gold, is influenced by the laser wavelength of the Raman instrument used.
  • Understanding of SERS principles and applications
  • Familiarity with vapor-deposition and electrochemical techniques
  • Knowledge of Raman spectroscopy and its instrumentation
  • Experience with colloidal systems and sol-gel processes
  • Research glancing angle deposition techniques for SERS substrate fabrication
  • Explore the properties and applications of Klarite SERS substrates
  • Investigate the effects of surface roughness on SERS signal enhancement
  • Learn about the compatibility of different metals with Raman laser wavelengths
Researchers in the fields of biochemistry, materials science, and analytical chemistry, particularly those involved in SERS applications and the study of biological materials.
newlabguy
I'm interested in coating a coverslip with a thin layer of silver for SERS. I intend to grow a salmonella biofilm on it afterwards and get the spectrum. Does anyone have any experience with SERS and if so can you give me your advice for preparing SERS substrates to adsorb biological materials to. I've heard of the vapor-deposition method and also colloidal suspensions but have no practical experience making them.
Chemistry news on Phys.org
Hi there -
The crucial thing to do is deposit a roughened layer of silver. This can be done by many methods depending on what equipment and chemicals are available to you. You can sputter coat a semi-rough silver layer just using a standard machine, but the surface will be quite contaminated and will oxidise very rapidly (it also won't be too rough). Alternatively, you can coat the slide using a wet chemistry method then roughen using electrochemistry.
The best way of fabricating a systematically roughened silver substrate is to use an evaporator and do what is called glancing angle deposition, where the substrate is held at a high angle relative to the silver source - this usually results in the growth of nanorods or pillars which give excellent SERS signals.
The final way is just to purchase commercially available materials - you can purchase colloidal systems or sol-gel's very straightforwardly. My company makes and sells Klarite, a commercially available solid-state gold SERS substrate. For reproducibility, any commercially available solution is likely to be much better than what you can achieve in your lab.
Finally, your choice of SERS substrate metal is of course determined by your instrumentation - silver will require a Raman instrument with a 514 or 532nm laser (maybe 633nm) while gold will work better at 633 and 785 nm.
Hope this helps.
  • · Replies 19 ·
11K
11K
  • · Replies 21 ·
