Velocity of a Ball Thrown from a Building
  • Thread starter Thread starter chawki
    Air Ball
The problem involves a ball thrown from the top of a 48 m tall building with an initial velocity of 12 m/s. The main question is to determine the velocity of the ball when it reaches the ground, considering the effects of gravity.
  • Mixed
  • Participants discuss various equations of motion, particularly those involving constant acceleration. Some suggest using equations that relate initial and final velocities with displacement, while others question the assumptions about direction and the height the ball reaches after being thrown upwards.
The discussion is ongoing, with participants exploring different interpretations of the equations involved. Some have provided guidance on the correct forms of the equations, while others are clarifying the implications of the signs used in calculations. There is no explicit consensus on the final approach yet.
Participants are navigating the complexities of initial velocity direction and its impact on the equations used. There is an emphasis on understanding the role of gravitational acceleration and the importance of sign conventions in the equations of motion.
chawki
A ball is thrown up from the top of a 48 m tall building with an initial velocity of 12 m/s.
What is the velocity of the ball at the ground?
V=-9.81*t+12 ?
hi chawki! :smile:
you need one of the other constant acceleration equations …
yours uses vi vf a and t, but you don't know t :redface:
you need one that uses vi vf a and s :wink:
just use v2 = u2 + 2as
chawki said:
V=-9.81*t+12 ?
That's the velocity as a function of time. What about the position?
it shouldn't be V2-V02= - 2*g*h ? since we are throwing upward.
and we don't know how much the ball got higher before falling
i gave you the eqn in original ... you should the direction yourself
V2=(-2gh)+V02
V=28.24 m/s ?
chawki said:
V2=(-2gh)+V02
V=28.24 m/s ?
no
isn't -2gh positive ?
chawki said:
V2=(-2gh)+V02
That's fine. (Assuming you use the correct value for h, which really should be Δh.)
V=28.24 m/s ?
But you messed up somewhere. Show what you plugged in where.
That equation doesn't depend on the direction in which you throw. The negative sign is correct because the acceleration is -g (taking down as negative). But what's 'h'? That's where sign is also important.
v2 and u2 will be positive no matter what
what do you think will be signs of s and a ?
tiny-tim said:
no
:blushing:
i understand Δh=-48m ? ( but still i wonder how much the ball got higher when we throw it upward)
well..if Δh=-48
V= [tex]\sqrt{}-2*9.81*-48+12^2[/tex]
V= 32.95 m/s
V= 32.95 m/s
Yes its right
And next time wry writing "-2*9.81*-48+12^2" inside the bracket of sqrt in latex ... LOL ... :smile:
Good.
That's a different problem, but you can use the same equation to solve it. In that case you'd be solving for Δh.
Doc Al said:
Good.
ok, so i understand it doesn't change anything in our solution how much the ball got higher? we use only the height from the initial throw to the ground ?
That's right. When the ball comes back down to its initial level, it's going at the same speed it started out at. We don't need to know how high it went.
That's very interesting.. Thank you so much :blushing:
so it's like we throwed the ball downward with an initial speed?
and in that case..wouldn't be V2-V02 = 2*g*h ?
with h=-48m
and then we have a problem..we can't find the root of a negative number...
Right. Whether you throw the ball up or down, you'll get the same speed when it reaches the ground. Obviously throwing it up means its trip to the ground takes longer.
No. The equation doesn't change. It's the same regardless of the direction you throw.
with h=-48m
That's because you made the acceleration positive. But gravity still acts down.
I have learned that the equation of throwing a ball downward is typicall to free fall eauation..which is: V2-V02 = 2*g*h
That equation should be:
V2-V02 = -2*g*Δh
The minus sign is important. (a = -g = -9.8 m/s^2)
<offtopic post>
I had the change the title: I couldn't keep reading the title "throwing up"!
V2-V02 = -2*g*Δh
are you saying that in case of free fall, we write: V2-V02 = -2*g*Δh
Yes.
cristo said:
<offtopic post>
:smile: Yeah, not the best title choice.
sorry :blushing:
I'd have changed it to "throwing up (sic)" :biggrin:
and then washed my hands of it! o:)
v2-u2 = 2gΔh is the eqn in its pure form ...
to use it ... just choose anyone direction (up or down) as positive(just like Y axis) and other as negative(obvious)
and then write the values with signs corresponding to your direction ...
like ... if you choose up as positive then eqn would be ...
v2 - 122 = 2(-9.8)(-48)
v2 - 122 = 2(9.8)(48)
thus v = 32.95 m/s
and in case you throw the ball down ... (taking up as positive)
v2 - (-12)2 = 2(-9.8)(-48)
so you get same answer
... and this is in very obvious ...
when you throw the ball up ... it goes to max height and then return to the thrower's level having same speed 12 but now downwards ... so obviously of you initially throw the ball downwards ... it will still gain same speed when it reached the bottom
thus v = 32.95 m/s
Let me get this right,
in case of falls and throwing down with initial speed, the equations are:
h=1/2*g*t2+V0*t
V=g*t+V0
V2-V02=-2*g*Δh ?
in case of throwing the ball upward, the equations are:
h=-1/2*g*t2+V0*t
V=-g*t+V0
V2-V02=-2*g*Δh ?
h=1/2*g*t2+V0*t
V=g*t+V0
V2-V02=-2*g*Δh ?
h=-1/2*g*t2+V0*t
V=-g*t+V0
V2-V02=-2*g*Δh ?
No. The equations should be the same for both cases. The acceleration is always downward, a = -g.
The only difference between throwing the ball upwards versus throwing it downwards is the sign of V0: In one case, V0 = +12 m/s (for example); in the other, V0 = -12 m/s.
  • · Replies 38 ·
  • · Replies 19 ·
