| New Reply |
B-field question Lorentz's force |
Share Thread |
| Mar26-11, 09:07 PM | #1 |
![]() Uploaded with ImageShack.us 3. The attempt at a solution I think this problem is deeper than it looks. Here is my FBD ![]() Uploaded with ImageShack.us So I am assuming at it actually "stops" and "drops" when the magnetic force is exactly 180 degrees with Fg and then it falls under constant velocity? In other words [tex]qv_{0}B = mg[/tex] [tex]v_0 = \frac{mg}{qB}[/tex] Then [tex]y(t) = \frac{mgt}{qB} + y(0)[/tex] Now my problem is, what is y(0)? |
| Mar26-11, 10:46 PM | #2 |
Mentor
I suspect you are to ignore gravity. At any rate the effect of gravity will be minuscule compared to the Lorentz force.
The electron will undergo uniform circular motion once it enters the region with the B field. It's path will be a semi-circle, after which it exits the field. What is the direction of the Lorentz force on the electron? |
| Mar26-11, 11:31 PM | #3 |
It's always inwards, if there is no gravity then won't it go into a circle forever?
| Mar26-11, 11:40 PM | #4 |
Mentor
Once it completes half a circle, it's back out of the field & headed back to the left, displaced by 4 cm.
| Mar26-11, 11:48 PM | #5 |
The velocity is the left, but the force is up
| Mar27-11, 12:25 AM | #6 |
I'll give it another shot
[tex]\frac{mv^2}{r} = qvB[/tex] [tex]v = \frac{rqB}{m}[/tex] [tex]\bar{v}t = \Delta x[/tex] [tex]\frac{rqBt}{m} = \pi r[/tex] [tex]t = \frac{\pi m}{qB}[/tex] |
| Mar27-11, 12:42 AM | #7 |
Sigh...I am alone again.
| Mar27-11, 12:59 AM | #8 |
What exactly do you mean by displaced by 4cm? Isn't it going in an arc?
| Mar27-11, 01:45 AM | #9 |
Mentor
| Mar27-11, 02:19 PM | #10 |
Is my answer wrong then...? For time
| Mar27-11, 05:45 PM | #11 |
Mentor
Find the speed, then the Kinetic Energy. |
| Mar27-11, 05:49 PM | #12 |
Sammy, I am still confused about the KE part, is it asking when it comes out? Or the change in KE during the whole process? If it is the whole trip, how do I find the tangential force?
| Mar27-11, 05:56 PM | #13 |
Mentor
Lorentz Force is perpendicular to the direction of motion (cross product) at all times. Therefore, the Lorentz Force does NO work on the electron, so KE is constant.
Io find KE, you need to find v. What is r for the circular portion of the motion? |
| Mar27-11, 06:13 PM | #14 |
I feel like you are trying to lead me to saying it is 2cm...but it isn't. When I mean tangential force, I don't mean the centripetal force I mean the one that's parallel to the tangential velocity
| Mar27-11, 06:17 PM | #15 |
Mentor
Read my previous post about the Lorentz Force.
And, YES, r is definitely 2 cm. |
| Mar27-11, 07:32 PM | #16 |
No the Lorentz Force = centripetal force, which not the force I am talking about.
How do I find the force that is parallel to the tangential velocity si what I am asking. |
| Mar27-11, 07:33 PM | #17 |
Mentor
There is NO other force in this problem.
| New Reply |
Similar Threads for: B-field question Lorentz's force
| Magnetic force and electric field, analytic problem about Lorentz Force. | Introductory Physics Homework | 12 | ||
| Lorentz force question | General Physics | 35 | ||
| Lorentz force -> Current in a gradient field | Classical Physics | 1 | ||
| Lorentz Force Law to determine the magnitude and direction of an electric field | Introductory Physics Homework | 10 | ||
| question about lorentz force | General Physics | 3 | ||
