Amplitude of wave stretched as well as red shift?
The discussion revolves around the effects of spacetime expansion on the amplitude and wavelength of electromagnetic waves, particularly in the context of redshift and how these factors influence the perceived brightness of distant stars. Participants explore theoretical implications and physical interpretations related to electromagnetic radiation and cosmological principles.
  • Some participants propose that the amplitude of electromagnetic waves may also stretch along with the wavelength due to spacetime expansion, potentially making distant stars appear brighter.
  • Others argue that electromagnetic waves do not exhibit transverse vibrations of a medium, and thus the amplitude does not increase in the same manner as wavelength.
  • A participant suggests analyzing the situation in terms of photons, noting that the frequency and energy of photons decrease with redshift, leading to a reduction in energy density.
  • There is a discussion about the correct interpretation of the factor by which energy density decreases, with some participants correcting earlier claims regarding the use of redshift notation.
  • One participant emphasizes that the original question pertains to amplitude changes, asserting that the amplitude of an electromagnetic wave is simply related to the electric field strength.
  • Another participant clarifies that the discussion of amplitude should consider how Lorentz transformations apply to electric and magnetic fields, while also noting that this is not a special-relativistic Doppler shift.
  • Some participants express confusion over the relationship between energy density, amplitude, and the implications of redshift, highlighting the potential for misunderstanding in the terminology used.
Participants do not reach a consensus on whether the amplitude of electromagnetic waves changes with redshift. Multiple competing views remain regarding the implications of spacetime expansion on wave properties and the correct interpretation of related physical principles.
There are unresolved issues regarding the definitions of redshift and the implications of Lorentz transformations in general relativity. The discussion also highlights ambiguities in language that may lead to confusion about the relationships between amplitude, energy density, and redshift.
SteveinLondon
The expansion of spacetime stretches and red shifts the wavelength of light. Is the amplitude of the wave stretched as well? So that very distant stars appear brighter, and therefor nearer?
Electromagnetic waves are not transverse vibrations of a medium. There is no actual sideways motion. It's not like photographically enlarging an image of a water wave, where the amplitude grows by the same scale factor as the wavelength.
Although this question can be answered purely classically, I think it's easier to analyze if you think in terms of photons. The photon's frequency is reduced by a factor z, so E=hf is also reduced by that factor. The volume occupied by the wave is increased by a factor of z^3, so the energy density is reduced by a factor of z^4. Since the energy density is reduced by z^4, the electric and magnetic fields are also reduced, by factors of z^2.
[EDIT] Marcus pointed out that z should be replaced with 1+z everywhere above in order to be consistent with standard notation.
Are you suggesting a distant star is "brighter" than a nearer star?? Is that what you think you observe? no.
Also, cosmic redshift does not occur over relatively small galactic distances but rather much larger interstellar distances...in the smaller regions gravity keeps everything pretty much in the same relative position...and nearby galaxies can be moving towards one another as well as away from each other...this could result in some redshift or blue shift...
Crowell:
No medium, I get that..what does the second part mean..."actual sideways motion" ??
The field oscillates that way, right...?
Wiki has a (correct) concise explanation and associated diagram here:
http://en.wikipedia.org/wiki/Electromagnetic_wave
Electromagnetic radiation (often abbreviated E-M radiation or EMR) is a form of energy exhibiting wave-like behavior as it travels through space. EMR has both electric and magnetic field components, which oscillate in phase perpendicular to each other and perpendicular to the direction of energy propagation.
This is a clear complete response to Steve, so there's really nothing to add, but it illustrates an ambiguity in the English language---how we talk about fractional increase and increase "by a factor".
Or, in this case the reverse: "decrease by a factor".
The energy density of the photons is actually decreased by a factor of (1+z)4
in the sense that that is what you divide the old density by to get the new density.
Beginners can get confused by this ambiguity in English.
For example if the redshift of some light is z = 0.5, then the energy of each photon has been reduced by a factor of 1.5 (you divide by that to get the present energy).
And the volume has been increased by a factor of 1.53
so the number of photons per unit volume is reduced by 1.53 (they are spread out in a larger volume).
So the whole effect on the energy density is to reduce it by a factor of 1.54 = a bit over 5.
So you divide the old energy density by a factor of 5 or so.
This does not have any simple intuitive relation to 0.54 = 1/16 so a beginner might get confused by saying "reduced by a factor of z4 = 1/16
Hi, marcus -- Thanks for the correction. I just didn't realize I wasn't using the standard definition of z.
That type of diagram is misleading if you don't interpret it correctly. The transverse stuff is the field vectors, which don't have units of meters.
Sorry, but the original question was not about the energy density, was it. It says 'does the amplitude change'? The amplitude of an electromagnetic wave is just |E|. The issue is simply a matter of how the Lorentz transformation acts on E and B. So I say it should be just one factor of 1+z.
Please take another look at the final sentence of #2.
It's not a Lorentz transformation. This isn't a special-relativistic kinematic Doppler shift. There are no global Lorentz transformations in GR.
I'm sure you meant 1.52 here for the inverse square law, didn't you?
"I'm sure you meant 1.52 here for the inverse square law, didn't you?
That's for the unit area...
Marcus was addressing the unit volume...
V = 4/3(pi)r3
V = 4/3(pi)r3
There's no sphere involved. For example, a photon from a laser would experience the same increase in its volume, by a factor of (1+z)^3. The increase in volume is because of cosmological expansion, not expansion of a spherical wavefront.
  • · Replies 19 ·
  • · Replies 26 ·
  • · Replies 132 ·
9K
