Can a magnetic field do work on a current-carrying piece of wire?
The discussion revolves around whether a magnetic field can do work on a current-carrying piece of wire, particularly in the context of a slidewire generator. Participants explore the implications of magnetic forces on moving charges and the nature of work done in electromagnetic systems.
  • One participant suggests that moving a sliding rod in a magnetic field generates a current and requires work, questioning if the magnetic force does negative work on the rod despite being perpendicular to its velocity.
  • Another participant argues that while magnetic fields do not do work on charges in a constant magnetic field, they can do work in other scenarios, such as when magnets interact or in non-uniform fields.
  • A third participant emphasizes that the work done in a generator comes from the mechanical energy input, not from the magnetic field itself, which does not do work on the charges directly.
  • Some participants note that blanket statements about magnetic fields doing no work can be misleading, as there are conditions under which magnetic fields can store energy and do work.
  • One participant raises a hypothetical scenario where a charge with a magnetic moment interacts with a non-uniform magnetic field, suggesting that work can be done in such cases.
Participants generally disagree on the conditions under which magnetic fields can do work, with some asserting that magnetic fields do not do work on charges while others propose that exceptions exist. The discussion remains unresolved regarding the implications of these differing viewpoints.
Participants express uncertainty about the implications of magnetic forces and energy conservation, as well as the conditions under which magnetic fields may or may not do work. There are references to the limitations of blanket statements in physics and the need for careful consideration of specific scenarios.
epsilonjon
[PLAIN]http://img826.imageshack.us/img826/2928/19002018.jpg
Suppose I have a slidewire generator as in the image above.
If I move the sliding rod to the right I generate a current in the loop, directed anticlockwise. It takes work to move the rod, since the induced current is interacting with the magnetic field and experiencing a force to the left. The rate at which work is done by the applied force is equal to the rate of energy dissipation in the circuit, since you can't violate energy conservation.
Is it not the case here that the magnetic force is doing (negative) work on the current-carrying rod as it moves? I do not understand this, as the magnetic force on a moving charge is always perpendicular to its velocity, and so can never do work.
This caused me to go over the derivation of the [tex]\vec{F}=I\vec{L}\times\vec{B}[/tex] equation for the force on a current-carrying wire in a magnetic field. The few books I have all use the same sort of method, whereby they take the magnetic force on an electron at some instant then multiply it by the total number of electrons in the wire. Now I am thinking how can this be correct, as they're implying that the force on the electrons in the wire will always be in this same initial direction, contradicting what they've said earlier about moving charges in a magnetic field undergoing circular motion?
If someone could straighten this all out for me I would really appreciate it, as I don't want to keep reading before I understand this properly.
Many thanks!
Jon.
Is it not the case here that the magnetic force is doing (negative) work on the current-carrying rod as it moves? I do not understand this, as the magnetic force on a moving charge is always perpendicular to its velocity, and so can never do work, or in your case negative work.
Many thanks!
Jon.
Only free charges move in circular orbits when traveling with velocity in a constant magnetic field. Free particles travel in straight lines unless acted on by a force. In this example the only force is the Lorentz force which is unable to add kinetic energy to the particle. Also, there is no change in potential energy when a particle moves in a constant magnetic field, so there can be no net change in energy for the particle.
A current is an example of charges moving under the force of an electric field, so the above does not apply. Even in your example, the magnetic field is not doing work because it is constant. Instead the voltage times current is the power that is doing the work.
However, this whole business of "the magnetic field doing no work" is a misleading statement because clearly magnetic fields can do work. If you bring two magnets together, work is done. Two parallel conducting wires can also do work. It's really only constant magnetic fields that do no work. This should make sense because the magnetic field has energy, and if it is constant, then its energy is constant and no work can be done by it.
This has been covered exhaustively in other threads, but no, magnetic fields cannot do work on charges. Note that two magnetic fields (from magnets) forming say a repulsive arrangement is really the same as the force between two current-carrying wires. And the work done by pulling the wires apart is done against the electric field forcing the current, not the magnetic field. (this is how a generator works, and it's also why no power is delivered to the field coil of a generator. All the power comes from the shaft rotation. Big hydro generators for example don't use permanent magnets, they use field windings to create the magnetic field. The only power delivered to them is that needed to overcome resistance losses. The magnetic field of the field coil does no work.)
I agree with the above comments related to motors and the OPs example, however, I'd like to make some comments and clarifications to indicate what I was trying to say above. Note that I clearly stated that the OPs examples were not a case of magnetic fields doing work.
Antiphon said:
This has been covered exhaustively in other threads ...
Precisely because blanket generalizations cause confusion and require clarification.
This is an example of a blanket statement that is usually true, but is misleading because counter examples can be found, unless extra conditions are added.
For example, take a charge of arbitrary shape and spin it. This charge will now have a magnetic moment that can interact with a nonuniform magnetic field, and the magnetic field can do work in this case.
Some might say that magnets and current carrying wires are not really the same, but let's assume they are the same. Two magnets can certainly do work, and yet, where is the electric field you are speaking of in this case? Assume we are working in the obvious stationary frame of reference.
The issue here is that a magnetic field can store energy, and that potential energy can be used to do work. Granted, the case of magnets (or wires) attracting is a dead end process because the stored energy is used up, and work would need to be done to separate them again. However, it would be incorrect to say that no work has been done when two magnets are brought together. For example, two magnets could be oriented in an attractive position in a tube with a spring between them. The spring would then compress and the magnets would move closer together. Here, the potential energy of the magnetic fields is converted into potential energy in the spring. Also, two magnets can be oriented in a repulsive arrangement in a tube, and this can act as a spring, all by itself. Energy can be stored and released by doing work with, or having work done on the magnetic spring.
So the more general statement you sometimes hear ("magnetic fields do no work") is even more misleading than the statement that "magnetic fields do no work on charges", since it is akin to saying that springs do no work.
Stevenb, thank you for taking the time to write a thorough answer - i definitely think i understand it better now.
If you don't mind I also have one more question... A changing magnetic flux through a conducting loop causes an emf to be induced in that loop, right? So say I have a little solenoid with a time-varying current going through it, producing a changing magnetic field, and I put this at the centre of a huge circlular loop, say 1 light-year across. There is a changing magnetic flux through the loop, so this still induces an emf in it, even though the cause and effect are so far apart? I do not understand how this could occur! :bugeye:
P.S. sorry if this has been covered elsewhere, but i did do a search and couldn't find anything.
Many thanks,
Jon.
Many thanks,
Jon.
Well, that is certainly a very good question, and is one I recall thinking of many years ago. I'm struggling to find a nice clean and simple explanation, so I'll think about it more, and perhaps expand on my answer later. However, I can get you thinking about this as follows.
One issue is your qualification that you have a "little" solenoid. If the solenoid is little, then the flux lines are going to circle back within your 1 light year loop. Hence, the net flux change will effectively be zero. It's actually very difficult to keep the leakage flux from coming back within even a small loop.
Now, what if we expand your question to a large scale (thin and very long, let's say 10 light years long) solenoid? Indeed, your question becomes a nice thought experiment. But, now consider your assumptions and think about how you would drive current into a 10 light year long solenoid. You now have a challenging field problem to solve because the electric current and electric fields for the solenoid are not instantaneous, as usually assumed in a table-top experiment. In the end, the solution for this problem will involve retardation effects and electromagnetic wave propagation. Not a trivial problem to solve and requires more than just Faraday's Law to do correctly.
Yeah I see now it's not as simple as just "put a little solenoid in it the middle and you get a flux" :p
To be honest I'm just starting to learn the basic physics behind inductors as I'm self-teaching myself a bit of electronics. I won't think too much more about this problem as I keep getting bogged down with little details. It's been about 3 weeks and I haven't even gotten to the section on R-L circuits yet! :-p
Cheers, Jon.
So, the magnetic forces generated in a motor by the magnetic fields is not doing work? But its the total input of the electrical energy?
What if the magnetic field was not contant but changing in time. Would the total force on the current change? Its confusing to me... Without the magnetic fields no force can be generated and no "torque" is created by the force... Based on Lorentz law : F = IL x B , its seem as if magnetic fields can do work on a wire carrying current in a 90 degree axial. Magnetic fields can never do work on electric charges?
https://www.physicsforums.com/showthread.php?p=3996836#post3996836
Post you're answers here please.
  • · Replies 20 ·
