What is the correct speed of the bullet at impact with the block?
  • Thread starter Thread starter doxigywlz
The discussion revolves around a physics problem involving a bullet colliding with a block, where the bullet becomes embedded in the block. The scenario includes concepts of momentum and energy conservation, particularly in the context of a spring system. Participants are trying to determine the speed of the bullet at the moment of impact based on the given parameters.
  • Mixed
  • Participants explore the application of conservation of momentum during the collision and conservation of mechanical energy during the spring compression. There are attempts to relate the initial speed of the bullet to the final speed of the bullet-block system.
Some participants have provided guidance on separating the collision and spring compression phases of the problem. There is ongoing confusion regarding the application of energy conservation during the collision, with multiple interpretations being explored. A few participants express frustration over not arriving at the correct answer.
Participants note that the bullet-block collision is perfectly inelastic, which affects the conservation of energy. There is also mention of the initial conditions of the block being at rest and the spring's role in the energy transfer after the collision.
doxigywlz
Basically, I understand this question but I keep coming up with the wrong answer! Please show me where I am going wrong!
A 12.0-g bullet is fired horizontally into a 100-g wooden block that is initially at rest on a frictionless horizontal surface and connected to a spring having spring constant 150 N/m. The bullet becomes embedded in the block. If the bullet-block system compresses the spring by a maximum of 80.0cm, what was the speed of the bullet at impact with the block?
Book answer: 273 m/s
My work:
Conservation of Mechanical Energy
(KE + PEg + PEs)i = (KE + PEg + PEs)f
1/2(12)(Vi^2) = 1/2(112)(Vf^2) + 1/2(150)(80^2)
soo... 6(Vi^2) = 56(Vf^2) + 480,000
and from Conservation of Momentum:
12V1i =112V2f
0= 56Vf^2 - 6 Vi^2 + 480,000
plugging in for Vi.. I get 87 x 6 (I think I'm wrong here..)
so 46Vf2 = 480,000
Vf = 32.0 m/s
12Vi = 112(32)
Vi = 299 m/s
Please, please, please help me! I'm going to go crazy!
During the collision of bullet with block, energy is NOT conserved. But momentum is. After the collision, the combined "bullet + block" will have a final speed, and thus a kinetic energy. Energy is conserved during the compression of the spring.
are you telling me that the first part of the kinetic energy is equal to zero? sorry,i'm a little confused...
I don't know what you mean. Treat this problem as having two related parts:
(1) the collision: use conservation of momentum
(2) the spring compression: use conservation of energy
i hate to be a bother... but isn't that what i did?
No. You tried to apply conservation of energy during the collision--that won't work.
doxigywlz said:
My work:
For the collision, only use conservation of momentum to relate Vi to Vf.
okay, i think i see what you mean. so... will it be m1v1 + m2v2 = (m1 + m2) vf ??
Right. (v2 = 0)
okay, so then i have
V1i = (112/12) Vf
and then
(12)(V1i)^2 = 12 V1f^2 + 100 V2f^2 + (150)(80)^2??
V1i = (112/12) Vf
Right.
and then
I have no idea what you are doing here. Instead, apply conservation of energy to the system after the collision. Hint: After the collision, the only speed involved is Vf.
i'm really confused... i don't get it. i tried what you said but I'm still not getting the right answer.
ooookkkkaaayyy... doesn't look like I'm getting going to get anywhere with this problem 2nite.
I thought you understood the problem??
Well ok I'll try to explain..
Imagine a Bullet... It collides with a wooden block and stays inside the block, What type of collision this is Doxi? Of course perfectly inelastic (Well an ideal case), so energy is NOT conserved (look up elastic collision), but Momentum is conserved.
So let's start with our first equation.
[tex]m_{bullet}v_{bullet} + m_{box}v_{box} = (m_{bullet} + m_{box})v_{both}[/tex]
we know the box initially is at rest so.
[tex]m_{bullet}v_{bullet} = (m_{bullet} + m_{box})v_{both}[/tex]
But we have 2 unknowns! :cry:
But WAIT! Mechanical Energy is conserved for our bullet+box system!
:bugeye: :biggrin:
Conservation of Mechanical Energy [Conservative System]
[tex]\Delta K + \Delta \Omega = 0[/tex]
[tex]K + \Omega = K_{o} + \Omega_{o}[/tex]
so, we analyse two points we can use, we can use the point when the box+bullet system get in contact with the spring (spring at equilibrium) and the point where the spring is at its max extend and there's no speed for our system.
[tex]\frac{1}{2}(m_{bullet} + m_{box})v_{both}^2 = \frac{1}{2}kx_{max}^2[/tex]
Note: i was trying to be funny, because sometimes thinking "funny" works
:rolleyes:
thanks, by the way... that helped a lot
