Pairing mechanism for low-energy supersymmetry in string theory
352 replies · 169K views · last reply
arivero
In post #549 here I answered:
arivero said:
This is the blindness -the wrong turn- I try to fight in the last years: our world IS susy at low energies, and because of it we confused the pion with the muon in the fifties.
It was a very prepostereous thing to say, so five minutes after proposing it (basically a couple of publications by John H. Schwarz in 1971, following the discovery of the Ramond string), everyone, including Schwarz, forgot about it. But with three generations, the degrees of freedom match. It is susy, it is the qcd string, they were right from the start, and the only point today is why the non-chiral interactions get their gauge bosons massless, but not the partners. If we find the gauginos -and only them- the question will be settled.
And then I was surprised by the comment of Tom, asking how the pairing was done. Well, I thought that I had discussed it in some thread in BSM, but after looking at it, it seems that I did only a few sparse remarks here and there. On other hand, people was not liking to interrupt the flow of the thread and I have been either contacted privately or suggested to open a new thread. So here it is. The development can be traced in some draft papers:
http://arxiv.org/abs/hep-ph/0512065 http://arxiv.org/abs/0710.1526 http://arxiv.org/abs/0910.4793 http://www.vixra.org/abs/1102.0034
Next post is my answer to Tom question. Keep in mind that we produce squarks, while the quarks are just the ingredient to terminate the extremes of the string.
look at the data.
It is about taking seriously the ideas of http://dx.doi.org/10.1016/0370-2693(71)90028-1" ): the fermion in the dual model is susy to gluonic strings. So now all you need is to terminate the gluonic string. Regretly in 1971 there were only three states available to terminate the string: u, d, and s. Now we have the full history, and the experimental data tell us that we can terminate the gluonic string with five and only five different states: u, d, s, c, b.
So just count, please, just do the SU(5) global flavour game, and count. How many states do you get of charge +1? six, by terminating with particle and antiparticle. How many of charge +2/3? six of each colour, by terminating with an antiparticle at each end of the string. How many of -1/3? six. How many +1/3, -1, -2/3? Same: six, six, six. And how many neutrals? of course, twelve: the other half of the 24 of SU(5).
BONUS: Does it means that string theory, given as input the 3-2-1 gauge theory of the SM, predicts three generations? No exactly; only if we require that the neutral leptons must be produced too. If we only look at the quark sector, then any pairing of [itex](2^{p})[/itex] "up quarks" with [itex](2^{p+1} -1)[/itex] "down quarks" will produce equal number, [itex]2^p (2^{p+1} -1)[/itex] of up and down combinations, and p=1 is just the simplest case. Numerically minded people will notice that p=4 amounts to 496, but a theory with 16 light "down" quarks, 31 light "up" quarks and a total of 248 generations seems not to be the object that Nature has offered us.
EDIT: Allow me a correction to this remark: Of course, the quark sector condition works for any integers [itex]q[/itex] and [itex]2 q -1[/itex], with [itex]q[/itex] an even number, not necessarily a power of two. But that the powers of two are an interesing subset was noted by Peter Crawley in other thread time ago and I am kind of obsessed with this, because it could constitute the way to reconnect with usual string models, via the above p=4 case.
EDIT: other references using "fermion-meson": L. Brink and D. B. Fairlie http://dx.doi.org/10.1016/0550-3213(74)90529-X Nuclear Physics B Volume 74, Issue 2, 25 May 1974, Pages 321-342 ; Edward Corrigan and David I. Olive http://www.slac.stanford.edu/spires/find/hep/www?j=NUCIA,A11,749 Nuovo Cim.A11:749-773, 1972. Modernly, there are some papers, in the framework of SQCD and also in Holography, that work with "mesinos", generic susy partners of mesons. But note that phenomenologists restrict the name "mesino" to the composite combination of squark and quark
Can you present a table (or a ereference) where the pairing is shown explicitly?
Why do you use SU(5) instead of SU(6)?
How do you count different charges like color, flavor, weak isospin and hypercharge and all that?
Because the top quark doesn't bind into mesons (nor diquarks, for the same token).
This is, I am promoting an experimental peculiarity (that the mass of the top is higher than both the QCD scale and the W mass) to a main role.
But you can look also at it from a pure theoretical side. Take SU(3)xSU(2)xU(1) as given, and assume that SU(3) is the force that, at some scale, has this role of building the open string, this is, of binding pairs of particles. Then:
- First, you ask if there is some number of generations such that the possible pairs of terminations are in the same number that the squarks for these generations. The answer is none, so:
- Second, you go for the lesser goal: ask if there is some number of generations so that a subset of the quarks are the same number that the squarks you should have. The answer is yes, that q quarks of type down and 2 q - 1 quarks of type up, when q>1, combine to from the squarks needed for q (2q-1)/2 generations of particles.
- Third, make features out of bugs: postulate that the quarks that do not participate in the binding must have a high mass. On first approach, you can think that the subset of binding quarks should be massless, and the other of infinite mass. And we know from Nature that it is enough for them to have a mass equal or higher than the electroweak scale.
- Fourth, if you wish, add leptons to the mix. Of course leptons doesn't bind, they are SU(3) neutrals. But you want to produce sleptons. It happens that any solution of the second step also produces the needed number of charged sleptons (check combinations, now with quark/antiquark). And only for the simplest case, q=2, we get the expected number of neutral sleptons.
So, the full answer is, we do not use SU(6), because Nature hints us that we can relax to use another smaller number of flavours. Inspection of the quark sector tell us that we can use SU(q+2q-1) with q>1, and of all of these SU(3q-1), only SU(5) produces also the neutral sleptons.
s in squark and slepton stands, as usual, for "scalar". It refers to the spin zero partners of the elementary fermions, so that the electron has two slepton partners of charge -1, the positron has two slepton partners of charge +1 and so on.
arivero said:
It is about taking seriously the ideas of J.H. Schwarz... the fermion in the dual model is susy to gluonic strings.
I think you are misinterpreting the paper. The "duality" in dual models (Dolen-Horn-Schmid duality) is that you get the amplitude by summing over s-channel diagrams or by summing over t-channel diagrams, not by summing over both at the same time as in ordinary field theory. The string theory explanation is that the dual-model s-channel sum and the dual-model t-channel sum are just different representations of the same sum over string histories, but with the world-sheet cut in different ways (in order to define a path integral). This is mentioned very briefly in Appendix A of Polchinski (page 332, "Relation to the Hilbert space formalism"), where he calls it "world-sheet duality". But this is not supersymmetry.
mitchell porter said:
I think you are misinterpreting the paper. The "duality" in dual models (Dolen-Horn-Schmid duality) is ... But this is not supersymmetry.
Hey, no, I never told that the duality of dual models is a supersymmetry; what we know is that the fermions in the dual model are known to be supersymmetric to the bosons in the dual model. Of course this discovery is going to happen after 1971. First they are going to discover wordsheet susy, then years later they are going to discover that it also implies Space Time susy. But never, neither by them -at least in the mainstream- nor by me, a dual model setup between fermions and bosons has been claimed. I am sorry that my wording could be misconstrued in this sense.
The reason to quote this paper is to show that, in the years after the discovery of the fermionic states of the string, by Ramond and then by Neveau-Schwarz, there was no problem to see the string as a holder both for quark and gluonic states, which is the thing I am using: elementary fermions (quarks and leptons) in the fundamental level of one side, gluons (mesons, diquarks) in the fundamental level of the other.
Some years later, with the standard model already established, it could seem strange to have elementary entities on one side and composites in the other, so Schwarz took the bold step of promoting the bosonic sector also to the status of elementary, moving all the game to Planck scale. My claim is that this was the wrong turn, and that the initial view of fermions plus gluons was the right one, when gluons are terminated with light quark states.
arivero said:
... the bold step of promoting the bosonic sector also to the status of elementary, moving all the game to Planck scale. My claim is that this was the wrong turn, and that the initial view of fermions plus gluons was the right one, when gluons are terminated with light quark states.
Still, it is amusing that if I forget about the neutral sector, then there is also a solution with a total of 248 generations. This joins to other "2-sigma signals" of a link between the solution with five flavours and the solutions that appear in critical superstring theory. Marcus and Sagnotti found an interpretation of SO(32) as an open string with five different terminations. Usually this is guessed to be related to the tadpole count, related to the space time dimension. And if we had some reason to look only for the particular "Mersenne" solutions (with the number of up quarks being a Mersenne prime instead of a generic 2 q -1), we could invoke hep-th/9904212 to claim that our solution is the result of going from D=10 to D=4
I can find at least one example of supersymmetry between elementary excitations and composite excitations [edit: http://arxiv.org/abs/hep-th/0207232" but maybe I got it wrong, will need to read later], so that approach to "hadron supersymmetry" really might work. But in Schwarz 1971, the mesons aren't superpartners of the fermions, the mesons are "DHS-dual" to the fermions.
More precisely, you mean that in a dual theory with fermions and bosons it is possible to build diagrams (the most typical, fermion-boson scattering) where the s channel particle is a fermion and the t channel particle is a boson, or reciprocally. I do not deny this. Both of them are elementary states of the string, are not they?
What I was pointing out, by referring to these old papers, was that in a first impression people has not problem to consider the Ramond fermion as a quark and the bosonic states as mesons or gluons. Then people puzzled about it and preferred to consider that speaking of fermions as quarks was just "customary speak" (example, in Scherk 1975 review) and then finally the whole theory was promoted to the status of GUT-Planck scale entities, so that nobody had to worry about the material interpretation of a open bosonic string as a terminated string. And yes, 20 years later we see D-branes coming as a revenge :-D but we are too far away from the original situation.
But a thing that we have learned along the way (one learns things, even during a long wrong turn) is that we need to produce the same number of bosonic and fermionic states. And that it must be so for each charge, because strings have susy, and susy commutes with the charge generators.
And amazingly, if one checks the original situation, the standard model with the gluonic string, one finds that it agrees with this requirement: their strings can be terminated, charge by charge, in a way that the number of boson and fermion states matches.
So the "wrong turn" was to consider the bosons in the dual model as fundamental rather than as composite, because what we need is a model exhibiting supersymmetry between fundamental fermions and composite bosons?
For a SUSY theory, not just the spectrum must be supersymmetric, but also the interactions between the particles. Otherwise the supercharges are not conserved. How would that come about here?
So far, I have not found a way to produce the gauginos with the same mechanism, the termination of open strings produces exactly all the needed scalars, but only them.
My personal expectation is that the LHC could find the gauginos but not the scalars, because the scalars are already there as QCD strings. It could be different if we were able to build the gauge sector as a kind of closed strings.
There are two puzzling lateral issues, related to the W and Z. On one side, a sort of "duality": that the sum of all the decays of Z seems to have the same rate that the decay of a pion having the same mass. On other, that the scalars that give mass to the Z and W are, in susy, partners of a chiral fermion, and that then we need six extra scalars (for Z, W, and Z0) for any mass mechanism, and three of them are eaten into the 0 helicities of Z and W. My guess is that these scalars are the ones we produce from uu terminations, which have no role in the reproduction of squarks and sleptons.
This is all quite interesting, but also rather hard to grasp at first glance. So for my own reference, and perhaps the edification of confused onlookers, let me present a two-paragraph idiot's guide to what's going on here.
1. There is an obscure research program or line of thought called hadronic supersymmetry. It proposes that quarks and http://en.wikipedia.org/wiki/Diquark" . The second paper, in particular, starts with a nice review of history and motivations, and also contains the most mathematically sophisticated approach that I've seen. I'm not saying it's correct, just that it gives a theorist more to work with.
2. Alejandro Rivero, in his papers listed in #1, proposes to extend hadronic supersymmetry to the leptons.
If anyone wants to understand what this discussion is about, I suggest that those are the two ideas to cling to. Alejandro is trying to motivate or implement his idea by digging up these "dual models" from the dawn of string theory, but it's very unclear to me whether his "path not taken" actually exists. Would different dual models or different string theories have been discovered, ones that we don't know about today? Or would the formal theory have developed in the same way, but with different ideas about phenomenology? For my part, I intend to read Catto 2003 next, understand his model of hadronic supersymmetry, and then see what Alejandro's proposed extension looks like when Catto's approach is used as a base.
Indeed Lichtenberg and Catto are relevant references, but I was disappointed that they were only using it as a way to calculate baryon masses. As they are not interested on the fundamental level, they fail to appreciate the miracle that happens when three generations and five light quarks are considered. On the contrary I think that this miracle, and its uniqueness, is important and tell us something about our expectations to find the partners of the standard model particles.
(still, I am going to re-read them... Thanks for the reminder!)
At least, the scalars. I can not tell anything yet about the other bosons, nor the gauginos. As for the "because", I would not say that "we need". It is just that susy happened as a prediction of the evolved R-NS dual model, and that string theory (and dual models) does not need to take strong positions on the issue of compositeness vs fundamental. Of course, the "right turn" had been to postulate that the endings of a bosonic open string were forcefully light fermions of the same theory, and then in 1975 they had predicted three generations and a non-light top quark.
Currently I am fantasising that at the end of the path we had investigated the case with 16 up quarks and 31 down quarks, producing 16*31 = 496 ud combinations and (31*32)/2 = 496 dd combinations and so 248 generations (each generation, of course, needs two scalars to pair each fermion of a given charge), and then the scalars from the extant (16*17)/2= 136 uu combinations had been used to give mass to some objects, breaking some underlying symmetry group from 248 elements to something with 248 - 136 = 112 elements. Or something so :biggrin:
the joke was about the decomposition of E8 as a sum of representations of SU(2)xE7, this is (3,1)+(1,133)+(2,56): the whole representation is a 248, while the last subrrep is a 112. If you were guessing other family of objects, please tell me!
tom.stoer said:
Sorry to say that, but I think this simply does not sound right. It's a gut feeling ...
If you refer to #15, it is only a (half-)joke. Mitchell wondered if the formal theory had developed in the same way, and I answered by pointing out that it was possible to arrive to write SO(32) or E8-like scheme even when starting from this empirical approach.
Or do you refer to the whole idea? I am very surprised that you all are not impressed. OK, I could understand that people only worried by gravity can fail to be impresed by any particle-related juggling. But if someone is into particles, to notice that the exact number of scalars of the SSM can be produced from this simple combination game -and with the right charges for almost all: charge only fails for the six scalar partners of the non-Dirac fermions who marry the W an Z-, well, it should deserve at least some weeks of attention. My opinion, of course.
Summary and prognosis:
Hadrons for the first n flavors have an approximate SU(2n) symmetry called "spin-flavor symmetry". http://prd.aps.org/abstract/PRD/v12/i1/p147_1" you may see De Rújula, Georgi, and Glashow employing first SU(6) spin-flavor symmetry (u,d,s) and later SU(8) (u,d,s,c) to explain hadronic properties.
As mentioned in http://arxiv.org/abs/hep-th/0302101" proposed that they might be placed into a single symmetry multiplet, but to do this he had to anticipate supersymmetry, since mesons are bosons and baryons are fermions. He extended SU(6) to SU(6|21); this was the real beginning of "hadronic supersymmetry".
The most commonly believed explanation of this, within QCD, appears to be that a meson is a gluonic string connecting a quark and an antiquark; and that inside a baryon, you end up with two quarks on top of each other at one end of a gluonic string, and with the third remaining quark at the other end; and that this structural similarity accounts for the shared Regge slope. This is the picture that Lichtenberg and Catto employ; and Nobel laureate Frank Wilczek is http://arxiv.org/abs/hep-ph/0409168" .
However, there is an alternative way to get http://arxiv.org/abs/0901.4508" , and it rests on a different, equally simple picture. Instead of a baryon being a string connecting a quark and a diquark, it's a string with a quark at either end and a third quark smeared along the string. In other words, the string itself is a fermionic string.
I think this, and the holographic approach to QCD, and Type II string models where all the standard model particles are open strings stretched between branes, together provide a context where the viability of Alejandro's idea can be explored. http://arxiv.org/abs/0910.5955" , so it may not even be necessary to regard the two approaches to hadronic supersymmetry as mutually exclusive. The extension to leptons is a lot more problematic, but I think we have here a set of tools flexible enough to explore many variations on the idea, but rigorous enough to ensure that questions do have unequivocal answers.
arivero said:
Or do you refer to the whole idea? I am very surprised that you all are not impressed. ... But if someone is into particles, to notice that the exact number of scalars of the SSM can be produced from this simple combination game -and with the right charges for almost all
The problem is that up now it's only algebra w/o any fundamental dynamics. It looks like a bottom-up approach, but I can't see if this will produce something like a dynamical theory - or perhaps it may - but this will then be some sort of string theory again.
Regarding gravity: w/o gravity there is no need for string theory as far as I can see; string theory requires SUSY + additional dimensions - which we do not see in nature. String theory seems to be kind of framework to "produce theories as something sitting on top of vacuum states". OK, this is nice but afaik there's no additional benefit. w/o gravity it seems that string theory is nothing else but a very complicated "dual reformulation" of a huge class of (SUSY) gauge theories.
That's the reason why I am not very much impressed.
Also, leaving the top out is like letting the fat kid not play ball, which conjures up unpleasant childhood memories for me. :-p
(More seriously, though, this is interesting speculation that I unfortunately probably won't have the time to fully familiarize myself with. There seems to be just enough fuzziness such that things might end up being merely a coincidence after all, if a suggestive one. Also, I'm unclear about the mass scales -- do the proposed superpartners have the same masses?)
And in fact one can go directly with susy without arguing about string theory, but still my feeling is that the algebra will have its origins from strings, at the end.
One could say that the coincidence for charged leptons is trivial, as it follows from the coincidence for quarks: given p,r quarks, the number of charged mesons of a kind is also p*r.
My hopes for leptons are based in some hints: One, that for neutral mesons it works only for the p=2 r=3 solution, ie the total of neutrals in SU(p+r) is (p+r)^2 - 2p*r -1, and it is a very happy think that oscillations have doubled the number of neutrinos from Weyl to Dirac. Two, that we have the muon at the same scale that QCD and particularly very near of the pion. And three, that the theory of Koide predicts the charged leptons from a quantity amazingly close to QCD "current quark mass". Of course there is some tension between this and the second point.
It is more as, the fat kid will be the goal keeper. And indeed unpleasant.
Hey, I think you have explained why topcolor and ETC (extended technicolor) theories are dismissed in favour of Higgs mechanism... the Higgs mechanism does not have any particular role for the top. But then it fail to explain why [itex]y_t=1[/itex]
What happens is that it is broken, but only mildly broken. And then all of the phenomenological work we have is not useful to us, because it is done on the assumption that the break is huge enough to hide the scalars up in the TeV scale.
No problem about it been a string theory, we were not telling that the wrong turn was to do strings, the wrong turn was to do "elementary Planck scale strings". And yes it is only algebra and we could do it without referring to strings nor dual models. But it does not seem to me an fuzzy or ad-hoc algebra. Let me review all the steps and what do we get in each.
  1. We postulate that some number [itex]r[/itex] and [itex]p[/itex] of two kinds of particles, call them A and B, must form equal number of combinations of kind AA and kind AB.
    There is no loss of generality. The number of combinations AA is [itex]r (r+1) / 2[/itex] and the number of AB is [itex]r p[/itex], so equality implies that
    [tex]r= 2 p -1[/tex]
  2. For the abelian U(1) charge, there are two posibilities: either A=0 and then AB has equal charge than B; or A not zero and then AA must be -B and AB=-A. In the first case the charged leptons have charge B, in the second case they have charge 3A. Note that the first solution is not really valid because AB should be an antiparticle, but I mention it because it is very similar to the exotic quark assignment found by anomaly arguments. With the second solution, we conclude that the A quarks are down quarks, and the B quarks are up quarks. We conclude that there are [itex]p[/itex] quarks of type "up" and [itex]r= 2 p -1[/itex] quarks of type "down".
  3. Note that for the total of combinations to be an even number -to do pairs of scalars- then [itex]p[/itex] itself must be even (because [itex]r[/itex] is always odd). So the minimal solution is [itex]p=2[/itex] [itex]r=3[/itex] and they produce six equal scalars and thus three generations of them.
  4. The number of charged "sleptons" of a given charge is [itex]p r[/itex] too, so always equal to the number of "down" type "squarks". No surprises here
  5. The number of neutral "scalarleptons" is, from SU(p+r) and substracting the charged ones, [itex](p+r)^2-1-2pr[/itex]. Asking it to be not two but four times the number of generations, we have
    [tex](p+r)^2-1-2pr = 2pr[/tex]​
    so that [tex](p-r)^2 = 1[/tex] and the only solution compatible with the quark sector is the minimal solution.
What about the combination BB? Where, there are [itex]p (p+1) /2[/itex] of them. For the above solution, it means three of each BB type. On other hand, the gauge part of the Supersymmetric Standard Model has six scalars in the W and Z supermultiplets. My guess is that the combination BB can not partner to three generations of Dirac particles and because of this it is somehow blind to vector-like charges, ie blind both to colour and electromagnetism, while it can see the chiral charges (hypercharge and perhaps SU(2)). Not seeing color, there is only three BB (uu, uc, and cc) and three antiBB, and then they would match with the above six scalars. This impression of mine comes with some extra support from the p=16 example I spoiled in #15 before, where the "BB" combination also had a role related to symmetry breaking (between SO(32) and SO(16) or between E8 and E7).
Let's look at this from another angle. Is the essential idea that all the sfermions (squarks and sleptons) are actually diquarks and mesons? Please correct me if that overlooks something - I have really struggled to get the idea straight in my head - but I think that is the qualitative essence of the proposal.
The strong version of the idea is as you describe. There is also a weak version, that the Supersymmetric Standard Model has a hidden global SU(5) symmetry, but this weak version is irrelevant here.
And there is a stronger version: that all the scalars of the Supersymmetric Standard Model are actually diquarks and mesons. This version needs more handwaving, because it involves some play with chirality, Dirac vs Weyl, etc. But in this version, also the scalars that give mass to the W and Z should be a peculiar kind of diquarks, build from the uu uc cc combinations.
So far I have three ideas for how to realize this:
1. Look for a http://arxiv.org/abs/hep-ph/9712389" in which this is a residual trace of supersymmetry among composite particles.
2. Look for a version of the supersymmetric standard model in which there is an http://arxiv.org/abs/hep-th/0207232" . It has to be an extra supersymmetry because in the SSM, by definition, the superpartners of the fundamental fermions are fundamental sfermions, not QCD composites, so if certain QCD composites are also superpartners of the fundamental fermions, it has to be a different supersymmetry.
3. Look for a "less than minimal" supersymmetric standard model, in which the only supersymmetry is the postulated relation between fundamental fermions and QCD composites. This is the fuzziest idea. It could involve looking for a hidden supersymmetry in the standard model itself, or for a hidden trace of supersymmetry in a supersymmetric theory broken to the standard model.
I have identified a class of models which seem ripe for the inclusion of "lepto-hadronic supersymmetry" (LHS): single-sector gauge-mediated supersymmetry breaking models, especially when approached holographically. There's too much to sum up now, but see http://www.claymath.org/workshops/lhc/kachru.pdf" (especially part 7).
These papers are all written under the usual assumption that the superpartners of the known particles exist at high energies, and the model-building choices reflect the interaction of that assumption with various other conventional assumptions about how the world works. So implementing LHS in this framework will necessarily subvert some of the model-building choices which are standard in this literature. But it really looks like it could be done!
Hey, really I am enyoing these talks. With things as gauge bosons involved in susy breaking, and compositeness for al the quarks except the top, it sounds very much as if they were following research lines near to the conjecture here, even to the "strongest version".
Also, it seems it is a hard job. Damn, give me another five years.
Let's look at this from a simple angle again. One version of what we're looking for would be a theory where hadrons are quarks bound by gluons, and where leptons are gluinos bound by squarks. Two immediate problems: there ought to be quark-gluino bound states too, and there ought to be leptonic resonances. How hard are those problems to fix, and are there other obvious problems?
I am not sure if it is the same theory, because I am not sure about how to describe leptons and quarks. I am intrigued that the QCD strings is inherently a bosonic string; can we build an extended string out of a fermionic field? I'd say no. Can we find a superpartner to the QCD string?
