Reciprocal Series of Positive Integer Factors: Convergence & Sum
The series of reciprocals of positive integers with only prime factors of 2 and 3 converges to 2. This conclusion is reached using the comparison test, comparing the series to the geometric series 1 + 1/2 + 1/4 + 1/8, which converges to 2. Each term in the original series is less than or equal to the corresponding term in the geometric series, confirming convergence. The sum is calculated using the geometric series formula S = a/(1-r), where a = 1 and r = 1/2, resulting in S = 2.
  • Understanding of geometric series and their convergence
  • Familiarity with the comparison test in series convergence
  • Basic knowledge of prime factorization
  • Proficiency in algebraic manipulation of series
  • Study the comparison test in detail to understand its applications in series convergence
  • Explore geometric series and their properties, focusing on convergence criteria
  • Investigate other series with specific prime factor constraints
  • Learn about advanced convergence tests such as the ratio test and root test
Mathematicians, students studying series and convergence, educators teaching calculus concepts, and anyone interested in number theory and series analysis.
Kenshin
The terms of this series are reciprocals of positive integers whose only prime factors are 2s and 3s:
1+1/2+1/3+1/4+1/6+1/8+1/9+1/12+...
Show that this series converges and find its sum.
this is my first time writing here. i hope someone can help me with this question.
Try working with (1+1/2+1/4+1/8...)(1+1/3+1/9+1/27+++++++) See if that covers the sum above...
Hello! Thank you for sharing this question. This is a very interesting series and it's great that you are looking into its convergence and sum.
To prove that this series converges, we can use the comparison test. This test states that if we have two series, one of which is always greater than the other, and the smaller series converges, then the larger series also converges.
In this case, we can compare our given series to the series 1+1/2+1/4+1/8+... which is a geometric series with a common ratio of 1/2. This series converges to 2.
Now, let's look at the series given to us. Every term in this series is either equal to or less than the corresponding term in the geometric series. This is because every term in our series has either 2 or 3 as its only prime factors, while the terms in the geometric series have all powers of 2 as their prime factors.
Therefore, our series is always less than or equal to the geometric series and thus, it also converges to 2.
To find the sum of this series, we can use the formula for the sum of a geometric series.
S = a/(1-r), where S is the sum, a is the first term and r is the common ratio.
In our series, a = 1 and r = 1/2.
Therefore, S = 1/(1-1/2) = 1/(1/2) = 2.
Hence, the sum of this series is 2.
I hope this helps! Let me know if you have any further questions. Good luck with your studies!
