Can gravitational influence be measured?
  • Context: High School
  • Thread starter Thread starter AstrophysicsX
    Gravitational
The discussion revolves around the measurement of gravitational influence exerted by objects, particularly focusing on how gravitational force can be quantified and the methods used to measure it. The scope includes conceptual clarifications and technical explanations related to gravitational force, weight, and the functioning of accelerometers.
  • Some participants propose that all objects exert a gravitational force relative to their size and question how this force can be measured.
  • Others argue that weight is the measure of gravitational force, with a focus on the symmetry of gravitational interactions between objects.
  • One participant challenges the direct measurement of weight, suggesting that scales measure mass or apparent weight rather than gravitational force directly.
  • There is a discussion about the role of accelerometers, with some participants asserting that they measure acceleration due to various forces, while others clarify that accelerometers on the Earth's surface measure gravitational acceleration.
  • A distinction is made between Newtonian and general relativistic perspectives on how accelerometers function and what they measure regarding gravitational influence.
Participants express differing views on the measurement of gravitational force and the role of accelerometers, indicating that multiple competing views remain and the discussion is unresolved.
Limitations include potential misunderstandings of the terms "weight" and "gravitational force," as well as the interpretation of accelerometer readings in different contexts.
AstrophysicsX
All objects exert a gravitational force relative to its size. The sun keeps Earth and the other planets in orbit this way. Is there any way to measure how much of this force objects give off?
I don't know what you mean by "give off". Weight is the measure of gravitational force.
As mathman said, the weight of an object (say, on the earth) is the measure of the gravitational force of the Earth on the object and so, because the situation is symmetrical, also the gravitational force of the object on the earth.
Similarly, we can measure the "weight" of a planet by information about the orbit.
You can't measure weight, not directly at least. Scales, depending on type, measure either mass or apparent weight (everything but gravity). Accelerometers measure acceleration due to everything but gravity.
In free fall, you mean? If an accelerometer was lying on the Earth's surface, it would measure the gravitational acceleration of the Earth, right? (Though I guess this can be interpreted as the acceleration of the refrence frame, rather than Earth's gravity.)
No. An accelerometer lying on the Earth's surface registers an acceleration of about 1g pointing upward. Here are two perspectives on how accelerometers work.
Newtonian point of view: An accelerometer measures the acceleration of the accelerometer due to the net real, non-gravitational force acting on the accelerometer. An accelerometer does not measure pseudo forces such as centrifugal force, Coriolis effect, etc.: Those aren't real forces.
General relativistic POV: An accelerometer measures the acceleration of the accelerometer due to the net real force acting on the accelerometer. Gravitation is a pseudo force in general relativity, and accelerometers do not measure pseudo forces.
Okay, I understand. Thanks for the explanation.
  • · Replies 38 ·
  • · Replies 29 ·
  • · Replies 18 ·
  • · Replies 58 ·
