How to verify a position vector points to a point inside a sphere?
The discussion revolves around verifying whether a given position vector points to a point inside a sphere defined by its center and radius. The specific case involves a sphere centered at (2,2,2) with a radius of 1.5 and a vector A=<3,2,1>.
  • Exploratory, Assumption checking
  • Participants explore the relationship between the distance from the sphere's center to the point defined by the vector and the sphere's radius. There is a question about whether a distance smaller than the radius indicates the point is inside the sphere, and some participants reflect on the implications of distances greater or less than the radius.
The discussion is active, with participants sharing insights about the distance formula and its relation to the sphere's radius. There is an acknowledgment of the need to consider the distance in relation to the radius to determine the point's position relative to the sphere.
Participants are considering the implications of the distance formula and the specific values involved, including the radius and the coordinates of the point in question. There is a focus on understanding the geometric interpretation of the problem.
yungman
Given a sphere center at (2,2,2) with radius of 1.5, given a vector A=<3,2,1>. How do I verify A point to a point inside the sphere?
Equation of circle:
[tex]\sqrt{(x-2)^2+(y-2)^2+(z-2)^2}=1.5[/tex]
I know A point to a point inside the sphere.
[tex]\sqrt{(3-2)^2+(2-2)^2+(1-2)^2}=\sqrt{2}\;\hbox { smaller than 1.5}[/tex]
Is any point that give number smaller than 2.25 indicate the point is inside the sphere? can you explain why?
Thanks
Alan
[tex] \sqrt{(x-2)^2+(y-2)^2+(z-2)^2}=1.5[/tex]
This equation will give any point on the surface of the sphere since the distance from the center to the surface is constant.
If your point is before the surface, would the distance be more or less than the radius?
It would be more than the radius if the point is outside the sphere.
I have to think a little about this.
Thanks
The way to go about this question is to examine the distance between the centre of the sphere and the point defined by the vector. If the distance is less than the radius of te sphere then you know that the point is inside the sphere.
Got it. thanks both of you for the help.
Alan
