Solved: RC First Order Circuit Voltage Drop after Switch Opens
The discussion focuses on calculating the voltage drop across a capacitor immediately after a switch is opened in an RC first-order circuit. The capacitor, with a capacitance of 100mF, is initially charged to 12V before the switch opens. After the switch opens, the Thevenin resistance (RTh) of the circuit is determined to be 9.6154 ohms, and the time constant (τ) is calculated as τ = RTh * C. Ultimately, the voltage across the capacitor at t = 0+ is derived from the voltage drops across the resistors in the circuit.
  • Understanding of RC circuits and time constants
  • Familiarity with Thevenin's theorem
  • Knowledge of voltage divider circuits
  • Basic calculus for solving differential equations
  • Study the application of Thevenin's theorem in circuit analysis
  • Learn about the behavior of capacitors in transient analysis
  • Explore the derivation and application of the first-order differential equation for RC circuits
  • Investigate the effects of different resistor values on the time constant in RC circuits
Electrical engineering students, circuit designers, and anyone studying transient response in RC circuits will benefit from this discussion.
raface
Find the voltage drop across the capacitor just after the switch is opened v(0+)
Most variables are in picture attached
C = 100mF
Vc(t)= Vc([tex]\infty[/tex])+[Vc(t+)-Vc([tex]\infty[/tex]))*e-(t-t1/[tex]\tau[/tex])
First i assumed that the capacitor would be charge in steady state before the switch is opened. This would mean it is a short circuit. So the voltage in the capacitor would be 12V? Not sure if this is correct.
Secondly i assumed that as t tends to infinity, after the switch is opened that the voltage across the capacitor will become 30V
I then worked put the thevenin resistance of the capacitor circuit after the switch is opened.
RTh = 9.6154 ohms
Then
[tex]\tau[/tex] = RTh * C
I am not sure how to apply this to the first order equation to find v(0+)
In steady state, the capacitor is an open circuit, so its voltage is the difference between the voltage drop at the 4 ohm, 6 ohm resistors, caused by the 5A source and the voltage drop in the voltage divider (5 ohm, 20 ohm) caused by the voltage source.
After the switch opens, the capacitor will be connected to ground via the 6 ohm resistor and will discharge. At t = infinity, the voltage in the capacitor will be zero.
