Coupling DC Motors with Timing Belt: Vibration Concerns?
The discussion revolves around the feasibility of coupling two DC motors using a timing belt in a dynamometer project, specifically addressing concerns related to vibration and stress concentration. Participants explore the implications of mounting a test motor on a leadscrew-based table and its potential effects on system stability and component longevity.
  • One participant questions whether mounting a motor on a leadscrew-based table could lead to premature failure of the leadscrew due to vibration and stress concentration.
  • Another suggests the use of vibration dampeners, specifically neoprene rubber sheets, under the motor mounting shoes, although they express uncertainty about their effectiveness.
  • A participant proposes that using a flexible coupling along with vibration dampeners could enhance the system's durability if selected carefully.
  • There is a consideration of using lead screws only for adjusting the motor in the direction parallel to the motors, not for bringing them closer together, which may influence the overall design approach.
Participants express varying opinions on the effectiveness of vibration dampeners and flexible couplings, indicating that there is no consensus on the best approach to mitigate vibration-related issues in the proposed setup.
There are unresolved questions regarding the specific impact of vibration on the leadscrew's longevity and the overall effectiveness of the proposed solutions, such as dampeners and couplings, which depend on their selection and implementation.
robs314
Just a short question.
As part of a dyno project, I am coupling two dc motors together with a timing belt. To allow the same rig to be used for different test motors, I am considering mounting this (test) motor on a table, which can be positioned in two directions on leadscrews. This would allow the same timing belt to be used.
Is this a sensible idea from a vibration/stress concentration point of view?
My reservations are that vibration will cause the table to creep towards the other motor.
Thanks
You could consider vibration dampeners which are just basically small square neoprene rubber sheets under the motor mounting shoes. I don't know if this will do enough good, however.
Thanks for your reply
Would you say, in your opinion, that mounting a motor on a leadscrew-based table is likely to lead to premature failure of the leadscrew due to vibration + stress concentration?
I'm still inclined to go ahead with it, simply because it allows so much flexibility in terms of fitting different motors. I'm thinking of only using lead screws to adjust the motor under test in the direction parallel to the motors, and not on the axis between the shafts (ie not to bring them together). An adjustable idling pulley (on a leadscrew again!) will take up the slack when a smaller pulley is used on the Motor Under Test side.
Thanks for your help
Vibration dampeners and also a flexable coupling will definitely help. I think you could make it last a reasonable period if these components are selected carefully.
16K
