Binary phase diagrams - understanding the eutectic point
The discussion centers around the understanding of binary phase diagrams, specifically focusing on the representation of materials at the ends of the diagram and the concept of the eutectic point. Participants explore the definitions and implications of these diagrams in the context of materials science.
  • Some participants propose that binary phase diagrams represent materials at 100% concentration on each end, with a 50-50% composition at the midpoint, but clarify that this can refer to either weight percent or atomic percent.
  • There is a suggestion that a complete phase diagram will specify whether weight or atomic percent is being used, and some diagrams may present both scales.
  • The eutectic point is described as the temperature and composition at which the solution can be entirely liquid, marking the lowest cooling point for specific material percentages.
  • A participant expresses appreciation for the clarification regarding the eutectic point and engages in a side conversation about another participant's avatar, which represents chemical-mechanical coupling.
Participants generally agree on the basic definitions of binary phase diagrams and the eutectic point, but there is some uncertainty regarding the specific metrics (weight vs. atomic percent) used in the diagrams.
There is a lack of consensus on the implications of weight percent versus atomic percent in the context of binary phase diagrams, and the discussion does not resolve which metric is more commonly used or preferred.
Femme_physics
1) So, does the binary phase always represent the materials 100% on each end? That is to say, if you have lead and antimony, the right side will always represent 100% of one of the two, and the other side will present 100% of the other. If we look in the middle of the diagram, it's 50-50%, right?
2) The eutectic point is basically an ideal point on the diagram that represents the lowest cooling point based on the certain percentages of each materials. This is a tested value.
Do I have it correctly?
Yes, but it might be 50%-50% by weight percent or by atomic percent. A complete phase diagram will tell you which one is being used. Some diagrams have one scale on the bottom x axis and the other on the top (see http://www.interfluxusa.com/images/Eutectic_graf.jpg", for example).
The eutectic point is the temperature and composition that marks the lowest temperature at which the solution can be entirely liquid.
Yes, but it might be 50%-50% by weight percent or by atomic percent. A complete phase diagram will tell you which one is being used. Some diagrams have one scale on the bottom x-axis and the other on the top (see here, for example).
Ah, I see.
Is a better way to put it :)
Thanks a bunch Mapes.
BTW - I've been wondering for a while now, what does your avatar represent?
It's meant to represent chemical-mechanical coupling: a melding of schematics for forces, springs, atomic force microscopy, nanoindentation, mortar & pestle, and ligand-receptor binding. Thx for asking!
  • · Replies 49 ·
  • · Replies 23 ·
