A conducting rod slides down between two frictionless vertical copper tracks
The problem involves a conducting rod sliding down between two vertical copper tracks in a magnetic field, with a focus on calculating the change in gravitational potential energy over a specified time interval.
  • Exploratory, Assumption checking
  • The original poster attempts to calculate the change in gravitational potential energy using kinematic equations and gravitational potential energy formulas, but expresses confusion over the assumptions made regarding the motion of the rod.
Some participants have noted the presence of electromagnetic induction forces acting on the rod, which may influence the calculations. The original poster acknowledges the feedback but does not indicate a resolution to their confusion.
The problem specifies that the rod moves at a constant speed, which raises questions about the assumptions related to free-fall and the forces acting on the rod.
cclement524
A conducting rod slides down between two frictionless vertical copper tracks at a constant speed of 4.5 m/s perpendicular to a 0.56-T magnetic field. The resistance of the rod and tracks is negligible. The rod maintains electrical contact with the tracks at all times and has a length of 1.2 m. A 0.82-Ω resistor is attached between the tops of the tracks. Find the change in the gravitational potential energy that occurs in a time of 0.20 s.
s = ut+ (1/2) gt^2
U = mgh
I found the mass of the rod to be 0.2528777 kg
Here's my attempt at the answer, but I went wrong somewhere (I'm positive the mass I found is correct):
From the kinematic relations
s = ut+ (1/2) gt^2
= 0 +(1/2)gt^2
= (0.5)(9.80 m/s2)(0.20 s)^2
= 0.196 m
The change in the gravitational potential energy is
U = mgh
=( 0.2528777 kg)(9.80 m/s2)(0.196 m)
= 0.485727 J
My second attempt:
When it comes to finding ∆h I assumed free-fall (used 'g') ... but the rod was falling at constant speed
so I tried ∆h = 0.9 m
=(0.2528777 kg)(0.9 m)
= 0.20483
Neither of these are correct, but I am confused as to where I went wrong.
there will be force due to electromagnetic induction. F = BIL
Got it-- thank you!
welcome.
  • · Replies 17 ·
10K
10K
