Power Spectral Density: Atmospheric Turbulence & Aircraft Stability
  • Thread starter Thread starter PujaSunil88
    Density Power
The discussion revolves around the concept of Power Spectral Density (PSD) in the context of atmospheric turbulence and its implications for aircraft stability. Participants explore the definition of PSD, its calculation, and its relevance to understanding turbulent flows and aircraft dynamics.
  • Exploratory, Technical explanation, Conceptual clarification
  • One participant seeks clarification on Power Spectral Density and its relation to atmospheric turbulence and aircraft stability.
  • Another participant explains that PSD indicates the distribution of power across different frequencies in a turbulent flow, using examples like vortex shedding to illustrate its significance.
  • A third participant adds that PSD is utilized to create gust models for simulating aircraft maneuvers and analyzing stability by exciting different modes of motion.
Participants generally agree on the importance of Power Spectral Density in analyzing turbulent flows and its applications in aircraft stability, but the discussion remains exploratory without a consensus on specific details or literature recommendations.
The discussion does not resolve the complexities of how PSD specifically affects aircraft stability or the precise methodologies for its application in modeling turbulence.
Individuals interested in atmospheric turbulence, aircraft dynamics, and the application of power spectral density in engineering contexts may find this discussion relevant.
PujaSunil88
Heya Everyone! I was going through topics on Atmospheric turbulence and their effects on stability of aircrafts...and I came across Power spectral density. I could'nt understand it properly. Could anyone please give me an idea of what it is an refer me some literatures / books on it or topics related with atmospheric turbulence and its effect of aircraft stability?
Power spectral density basically tells you how much power is in certain frequencies. For example consider measuring the air velocity at a single point in a turbulent flow for an arbitrary amount of time. You have measured the velocity in the time domain so you can plot velocity versus time. Using fast Fourier transforms you can convert this data to the frequency domain where the x-axis will be frequency and the y-axis will now be a measure of how much power is contained in a each frequency. So in a turbulent flow, a spike in the power spectral density at a certain frequency would likely indicate some kind of flow phenomena occurring at that frequency, for example vortex shedding from a cylinder which for certain Reynolds numbers occurs at a specific frequency.
I don't know too much about aircraft stability but I would imagine this would be important because flow phenomena at a particular frequencies could excite certain unstable modes of the aircraft.
RandomGuy is correct. I'll elaborate more on the uses in aircraft control.
The power spectral density is used to create a gust model to simulate random motion and/or certain maneuvers, such as pitch, yaw, roll, etc... Also it can be used to excite short period and long period modes. These models are used and applied as a disturbance model to simulate the desired gust frequency, shape or even strength to analyze the robustness of the model.
@Random Guy, Viscous low: Thanks a lot both of you! its been of great help!
  • · Replies 0 ·
  • · Replies 47 ·
13K
